[Geoserver-users] geoserver 2.7 war file deployed in Tomcat but will not start
I have an existing binary installation of Geoserver 2.7.1.1 running on
my Win2012 server which I now need to run on Tomcat v9 to get round a
CORS issue (thats another problem for another time). I have stopped the
existing Geoserver instance and installed Tomcat v9. All good so far.
Downloaded a Geoserver WAR file placed it in the Tomcat webapps folder
and deployed it via the Tomcat app manager. Whilst the WAR file does
upload into Tomcat it will not start. On the Tomcat App Manager page a
message comes back with the following:
FAIL - Application at context path /geoserver could not be started.
I took a look in the Catolina log file and I see this in there
"21-Jan-2016 16:31:21.429 WARNING [localhost-startStop-1]
org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup
'XStreamPersisterInitializer', but ApplicationContext is unset.
21-Jan-2016 16:31:26.288 WARNING [localhost-startStop-1]
'GeoServerSecurityProvider', but ApplicationContext is unset.
21-Jan-2016 16:31:42.179 SEVERE [localhost-startStop-1]
org.apache.catalina.core.StandardContext.startInternal One or more
listeners failed to start. Full details will be found in the appropriate
container log file
org.apache.catalina.core.StandardContext.startInternal Context
[/geoserver] startup failed due to previous errors"
i have tried searching around the web and to date have not found a
working answer. Can someone offer advice.
Grant.
Hi Grant,
I would also take a look to other logs if they are present.
Do you have any localhost.(date?).log around, with some additional info?
Daniele
On Fri, Jan 22, 2016 at 3:35 PM, Grant Bartlett <grant.bartlett@anonymised.com…> wrote:
“21-Jan-2016 16:31:21.429 WARNING [localhost-startStop-1]
‘XStreamPersisterInitializer’, but ApplicationContext is unset.
‘GeoServerSecurityProvider’, but ApplicationContext is unset.
container log file
[/geoserver] startup failed due to previous errors”
Grant.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Just have to ask a silly question: You didn't do both of "placed it in the Tomcat webapps folder" AND "deployed it via the Tomcat app manager", did you? Only one of them is necessary..
/julian
-----Original Message-----
From: Grant Bartlett [mailto:grant.bartlett@anonymised.com]
Sent: 22. januar 2016 15:35
Subject: [Geoserver-users] geoserver 2.7 war file deployed in Tomcat but will not start
I have an existing binary installation of Geoserver 2.7.1.1 running on my Win2012 server which I now need to run on Tomcat v9 to get round a CORS issue (thats another problem for another time). I have stopped the existing Geoserver instance and installed Tomcat v9. All good so far.
Downloaded a Geoserver WAR file placed it in the Tomcat webapps folder and deployed it via the Tomcat app manager. Whilst the WAR file does upload into Tomcat it will not start. On the Tomcat App Manager page a message comes back with the following:
"21-Jan-2016 16:31:21.429 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
21-Jan-2016 16:31:26.288 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
21-Jan-2016 16:31:42.179 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
21-Jan-2016 16:31:42.179 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/geoserver] startup failed due to previous errors"
i have tried searching around the web and to date have not found a working answer. Can someone offer advice.
Grant.
Site24x7 APM Insight: Get Deep Visibility into Application Performance APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month Monitor end-to-end web transactions and take corrective actions now Troubleshoot faster and improve end-user experience. Signup Now!
