Hello community,
after upgrading from 2.7.0 to 2.8.0 and pointing to existing external data directory the GeoServer 2.8.0 shows an error: “The requested resource is not available”.
Has structure of ‘data’ changed in 2.8.0?
Would you recommend to transfer own data (workspaces etc.) from external data dir to new data dir and to replace the external data dir with the new data dir?
Ciao,
Izabella
directory the GeoServer 2.8.0 shows an error: "The requested resource is
not available".
What does the log show for this error?
Has structure of 'data' changed in 2.8.0?
Not that I know of.
Do you possibly have a store type that is not supported in your new install?
For example, a missing extension, or something else changed in your operating
system install?
Brad
Hello Brad,
thank you very much for your support.
Before I started the update from 2.7.0 to 2.8.0 all worked fine.
In past I updated from 2.6.3 to 2.7.0 with the same update procedure.
I attached the GeoServer log at the end of this message.
Izabella
The GeoServer log shows:
2015-10-31 23:48:07,203 WARN [geoserver.catalog] - Error while getting feature type, flushing cache and retrying: java.nio.channels.ClosedByInterruptException
2015-10-31 23:48:07,204 WARN [shapefile.shp] - Could not open the .shx file, continuing assuming the .shp file is not sparse
java.io.IOException
at org.geotools.data.shapefile.shp.IndexFile.(IndexFile.java:110)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:259)
at org.geotools.data.shapefile.ShapefileSetManager.openShapeReader(ShapefileSetManager.java:51)
at org.geotools.data.shapefile.ShapefileFeatureSource.readAttributes(ShapefileFeatureSource.java:513)
at org.geotools.data.shapefile.ShapefileFeatureSource.buildFeatureType(ShapefileFeatureSource.java:472)
at org.geotools.data.shapefile.ShapefileFeatureStore.buildFeatureType(ShapefileFeatureStore.java:131)
at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:343)
at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:312)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:345)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:108)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:174)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:57)
at org.geoserver.catalog.ResourcePool.getCacheableFeatureType(ResourcePool.java:903)
at org.geoserver.catalog.ResourcePool.tryGetFeatureType(ResourcePool.java:884)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:878)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:865)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:120)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy100.getFeatureType(Unknown Source)
at org.geoserver.gwc.layer.CatalogConfiguration.isLayerExposable(CatalogConfiguration.java:444)
at org.geoserver.gwc.config.GWCInitializer.addLayersToNotCache(GWCInitializer.java:281)
at org.geoserver.gwc.config.GWCInitializer.initialize(GWCInitializer.java:151)
at org.geoserver.config.GeoServerLoader.loadInitializers(GeoServerLoader.java:150)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:130)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:240)
at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:141)
at org.geoserver.ows.Dispatcher.initApplicationContext(Dispatcher.java:195)
at org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:73)
at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:117)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:92)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.startup.HostConfig.reload(HostConfig.java:1464)
at org.apache.catalina.startup.HostConfig.checkResources(HostConfig.java:1442)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1626)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:328)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1374)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1530)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1540)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1519)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.nio.channels.ClosedByInterruptException
at java.nio.channels.spi.AbstractInterruptibleChannel.end(AbstractInterruptibleChannel.java:202)
at sun.nio.ch.FileChannelImpl.read(FileChannelImpl.java:164)
at org.geotools.data.shapefile.files.FileChannelDecorator.read(FileChannelDecorator.java:97)
at org.geotools.data.shapefile.shp.IndexFile.(IndexFile.java:93)
… 96 more
2015-10-31 23:48:07,204 ERROR [gwc.layer] - An error occurred trying to determine if the layer is geometryless
java.lang.RuntimeException: java.nio.channels.ClosedByInterruptException
at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:345)
at org.geotools.data.shapefile.shp.ShapefileReader.fill(ShapefileReader.java:314)
at org.geotools.data.shapefile.shp.ShapefileReader.init(ShapefileReader.java:333)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:266)
… 90 more
not available”.
Not that I know of.
system install?
Brad
Geoserver-users mailing list
