I would try what happens with the default data_dir that gets installed if you allow the installer to do it. If service starts then you know that the issue has something to do with your own data_dir. Next I would make a test by creating a new Oracle store and layer for seeing if that part is generally OK.
I think that GeoServer 2.8.0 does not work with old ojdbc jars like ojdbc14.jar but it requires newer like ojdbc7.jar. That’s the very first thing to check.
-Jukka Rahkonen-
Jacob Overgaard Madsen wrote:
Hi list
I really hope, that I can get some help here, because I’m on the verge of giving up. I currently administer a production Geoserver instance, which currently runs Geoserver 2.6.2. The operating system is Windows 2008 R2 x64, and it’s installed with the Windows installer with the default Jetty, installed as a Windows service, and runs on JRE 1.7.0_71 x86. This server runs fine. The data is almost 100% based on Oracle Spatial data, where I use the Oracle NG connection. My setup is quite large – 6000 layers, 300 stores and 300 workspaces currently and growing.
But due to recent improvements in the new version 2.8.0 regarding Oracle connections, I need to update this server to the new 2.8.0. But every attempt I’ve made so far to do this has failed. I have always – so far – been able to upgrade Geoserver by simply installing the new version, pointing it to the existing data directory during installation, choosing the same port and JRE as the previous version, and that’s it. But not this time. When I install 2.8.0 with the Windows installer, as I’ve always done, the Windows service is created etc. But the service will never listen to port 8080 (or any other port). A closer inspection of the Geoserver log file reveals, that the line indicating successful start of the port listener:
“Started SelectChannelConnector@…83…:8080” (taken from 2.6.2 log file)
never appears in the log file. The server simply stops loading before reaching this point without any useful information about what’s wrong in the log file. I have of course added the Oracle NG JAR and Oracle JDBC driver as always.
I have played around with various memory related settings in wrapper.conf, like I did with 2.6.2, but nothing seems to make the server start correctly. I have also tried installing the server without the Windows service – ie. having to start the server with startup.bat and shutdown.bat. This doesn’t seem to work neither. The server still loads the configuration from the data directory, until it simply stops and never starts the listening interface. Up until that point, the log file from 2.8.0 looks exactly like the log file from 2.6.2 – ie all data stores etc. seems to load correctly, and I can see the connections to the database being established by running a netstat. But the server never listens on any port.
My wrapper.conf settings from 2.6.2 are here:
Java Additional Parameters
wrapper.java.additional.1=-Djetty.home=.
wrapper.java.additional.2=-DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%”
wrapper.java.additional.3=-XX:MaxPermSize=1024m
wrapper.java.additional.4=-Xmx3072M
wrapper.java.additional.5=-Xms3072m
Initial Java Heap Size (in MB)
wrapper.java.initmemory=512
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=512
As I at some point made the assumption, that this had something to do with some kind of increased memory usage in 2.8.0, I figured, that I could try making Geoserver 2.8.0 run under Weblogic 10.3.6, which we also have. Running it under Weblogic would make it possible for me to run it as a 64-bit Windows service.
But this fails also. I have deployed by unpacking the Geoserver WAR file and want to get Geoserver running with the default data stores in the first place. But even this fails. Geoserver crashes with this error in the log:
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘webDispatcherMapping’ defined in URL [zip:C:/Oracle/Middleware/user_projects/domains/ClassicDomain/servers/AdminServer/tmp/_WL_user/geoserver/m2k7gc/war/WEB-INF/lib/gs-web-core-2.8.0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named ‘#{webDispatcherMappingSystem}’ is defined at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
followed by a long stack trace.
I have not been able to find any useful information about this error. In general, the information on how to deploy Geoserver in Weblogic is extremely sparse – some of it dates back to Weblogic 8.1 and is not very useful.
- Can somebody shed some light on what’s going on here?
- What has changed so badly in 2.8.x compared to 2.6.x, that I no longer can load my configuration under Jetty with the existing data directory?
- What does the error under Weblogic mean? Why can the bean “webDispatcherMappingSystem” not be loaded?
I just hope, that someone can help me get Geoserver 2.8.0 running either under Jetty + JRE7 x86 + Windows service or under Weblogic.
Thanks in advance,
Jacob Madsen
