[Geoserver-users] GeoServer Active Clustering Extension conflict with gs-jdbcconfig-2.5-SNAPSHOT.jar
I'm trying to setup GeoServer Active Clustering Extension
<http://geoserver.geo-solutions.it/edu/en/clustering/geoserver/active/installation.html&gt;
on a GeoServer 2.5.1 with gs-jdbcconfig-2.5-SNAPSHOT.jar already installed.
The GeoServer Active Clustering Extension
(geoserver-2.5-ENTERPRISE-SNAPSHOT-cluster-plugin ) is installed. However,
when GeoServer starts up, I'm getting the following error:
2014-09-18 18:17:07,417 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'geoServerLoader' defined in URL
[jar:file:/home/reap/data/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is
java.lang.IllegalArgumentException: Multiple beans of type
org.geoserver.config.GeoServerLoader
When I removed gs-jdbcconfig-2.5-SNAPSHOT.jar from the lib directory,
GeoServer started fine and then started to load all layers and stores into
memory and it takes about an hour or so. Prior to installing the GeoServer
Active Clustering Extension, GeoServer is configured with
gs-jdbcconfig-2.5-SNAPSHOT.jar to load on request. We would like to keep our
current setup with GeoServer Active Clustering Extension but something in
the clustering extension is causing this conflict.
Does anyone know why or have resolved this issue?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-Active-Clustering-Extension-conflict-with-gs-jdbcconfig-2-5-SNAPSHOT-jar-tp5162742.html
I'm still having these issues with the extension. Can anyone help me?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-Active-Clustering-Extension-issues-tp5162742p5163566.html
bean
our
I believe the two extensions are currently incompatible, they have been
developed
in isolation without ever being combined before.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
first of all, can you specify which Geoserver version and which active cluster extension are you using?
Then, which kind of issues are you experiencing in particular?
Thanks
Mauro
2014-09-23 19:50 GMT+02:00 nly <nly@anonymised.com>:
I’m still having these issues with the extension. Can anyone help me?
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
