[Geoserver-users] Geoserver--> After installing & starting the haproxy server, I am not able to login in Geoserver
I have installed the Haproxy server for load balancing. The scenario is
like:-
Geoserver1 :- 192.168.0.99:8080/geoserver
Geoserver2:- 192.168.0.98:8080/geoserver
Haproxy server is installed on 192.168.0.99 machine on port no 5000
url for haproxy :- 192.168.0.99:5000/geoserver
I want to do the performance testing like but not able to see, which
geoserver is handling the request. I am not able to login in the
"192.168.0.99:5000/geoserver" but it is showing all the layers which I have
added in the Geoserver1 & geoserver2. I am attaching the haproxy.cfg file
Thanks
Saurabh Kumar
haproxy.cfg <http://osgeo-org.1560.x6.nabble.com/file/n5164010/haproxy.cfg&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-After-installing-starting-the-haproxy-server-I-am-not-able-to-login-in-Geoserver-tp5164010.html
On Thu, Sep 25, 2014 at 7:49 AM, Saurabh.x.kumar <saurabh.x.kumar@anonymised.com>
wrote:
like:-
have
This is normal, the UI does not have any clustering support, so you have to
setup
haproxy so that it hits just one of the two nodes.
See here:
http://geoserver.geo-solutions.it/edu/en/clustering/load_balancing/haproxy.html
I believe the whole section about clustering will be of interest to you:
http://geoserver.geo-solutions.it/edu/en/clustering/index.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
localhost_access_log.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5164143/localhost_access_log.txt&gt;
Hi, Please see the log file & help me out.
Not able to login at 192.168.0.99:5000/geoserver URL.
Thanks
Saurabh Kumar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-After-installing-starting-the-haproxy-server-I-am-not-able-to-login-in-Geoserver-tp5164010p5164143.html
