I installed the latest version of Arc Explorer and Geoserver. When I try to connect Arc Explorer to geoserver via WMS, I can see all the test layers, but none of them load – I get gray tiles everywhere.
Six weeks ago, I was using Geoserver 2.2 and I was able to get Arc working in tadem with it just fine so I know what I am doing is possible. I have reverted back to geosever 2.2 in an attempt to fix my issue but to no avail.
Please help!
Thanks in advance,
Isaac
Hi Isaac,
Have you tried accessing someone else’s GeoServer or WMS?
You can find lots of public servers here:
http://geopole.org/tags/1358
That at least would indicate whether the current ArcExplorer install is able to handle a WMS.
Jonathan
On 15 January 2013 15:50, Isaac Gerg <isaac.gerg@anonymised.com> wrote:
Please help!
Thanks in advance,
Isaac
Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS
and more. Get SQL Server skills now (including 2012) with LearnDevNow -
200+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only - learn more at:
http://p.sf.net/sfu/learnmore_122512
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
