[Geoserver-users] Geoserver and ArcGIS 9.1 Question
Chris,
Thank you, it is working now.
I was running 1.2.3, after upgrading to 1.3 Geoserver is working great with ArcGIS 9.1.
Ken
Chris Holmes <cholmes@anonymised.com> 09/08/06 07:36PM >>>
Argh, you can sorta ignore my last email, I was thinking arcsde instead
of arcgis - these arc*'s confuse me.
Jukka's on the right track. You can also try GeoServer -> Demo -> Map
Preview and see if it shows your layer.
Also be sure that you have a good style. 1.3.3 has a nice SLD wizard
that lets you make a very basic style. If you select a point style and
serve lines than nothing will appear.
hope that helps,
Chris
Rahkonen Jukka wrote:
Can you get your data visible to some other client? You can try for example with browser with something close to this
http://localhosti:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=county_miv5a&BBOX=good_values_here&WIDTH=500&HEIGHT=500&FORMAT=image/png
If you cannot see your map with any client then I would suspect that it is not drawn, or it is drawn with some invisible style and you should check the style settings on your Geoserver. If is something ArcGIS related then I do not have any idea.
-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: Ken Hudak
Lähetetty: pe 8.9.2006 16:40
Vastaanottaja: Geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Geoserver and ArcGIS 9.1 Question
Hello,
I have added a shapefile featuretype to Geoserver on a local host. I then add my WMS service to ArcGIS 9.1 and it lists the data in the table of contents just fine. But I don't see any images at all in the map window. I've tried zoom to extent, zoom to layer, etc, and nothing.
From the ArcGIS Properties window, I can get the following info:
Data Type: WMS Service Sub-Layer
WMS Server: http://localhost:8080/geoserver/wms?Service=wms&
Service Name: My GeoServer WMS
WMS Layer Name: topp:county_miv5a
Default Coordinate System:
GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: 0
Supported Coordinate System(s):
EPSG:4326 - GCS_WGS_1984
Anyone know why the images(features) won't display in the map window?
Thanks!
Ken
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1003,4501848c316902095110867!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
