Chris,
I think it would be useful to limit the projections anyway.
For instance, if we serve out data in The Netherlands, it makes sense to
include WGS84 and ETRS89, and a few UTM zones, but the rest absolutely makes
no sense. So it would be useful if we could limit them, to protect people
from making ridiculous reprojections.
Also, Mapserver WMS client (through PHP/Mapscript) has a problem with the
string size of the combined SRS values ...
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Chris Holmes <cholmes@anonymised.com>
Naar: Joanna Muench <jomuench@anonymised.com>
Cc: Geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] GeoServer and beeldblad
Datum: 13/11/06 16:50
Currently there's no way to limit the projections GeoServer returns. A
few clients have complained about it in the past, but it's generally a
pretty easy fix for them. And from a technical perspective it's a bit
of a hack just to limit projections on the server so a specfic client
can deal with it. I'd recommend talking to their developers about not
creating a separate object for each projection returned. When
configuring the client it probably has a default projection, so could
just look for that on WMS's, instead of making a new object for every one.If they absolutely can not come up with a solution we can investigate
doing so on the geoserver side, but it would likely need a bit of
funding or volunteer time.best regards,
Chris
Joanna Muench wrote:
> Our group is hoping to use the beeldblad Flash client
> (http://nlr-gis.nlr.nl/beeldblad/index.html) to access a geoserver
WMS.
> When we tried it out, the client hung and never got anywhere.
According
> to the beelblad developers, the Flash client creates a separate
object
> for each projection returned in a getCapabilities request - which is
> sizeable for GeoServer! Has anyone else encountered this problem? Is
> there a way to limit the projections that GeoServer returns?
> Thanks, Joanna Muench
> IRIS Data Management Center
> www.iris.edu <http://www.iris.edu>
> !DSPAM:1003,4558b8b4235654750375898!
> Using Tomcat but need to do more? Need to support web services,
security?
> Get stuff done quickly with pre-integrated technology to make your
job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> Geoserver-users mailing list
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> !DSPAM:1003,4558b8b4235654750375898!--
Chris Holmes
The Open Planning Project
http://topp.openplans.org-------------------------------------------------------------------------
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
