Dear Daniele, your advice is proving useful, thanks, I haven’t had time to apply myself to the problem since then but will give quality time to the installation when I return from holiday in a couple of weeks.
I look forward to the updated Geoserver documentation as it seems I’m not the only one grappling with these issues. Thanks again. David
@boscinet
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: 16 July 2015 11:30
To: David Lovelace; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geoserver and ecw raster formats
Dear David,
did you make any progress with your GDAL installation?
Do the latest provided feedbacks helped you in this process?
In the meantime, we are also updating the GeoServer documentation with some more details.
Daniele
On Tue, Jul 7, 2015 at 1:53 PM, David Lovelace <david@anonymised.com> wrote:
Dear Daniele,
Yes you are right. Tomcat log includes this (I’ve only been looking at the geoverver logs):
“WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
java.lang.UnsatisfiedLinkError: C:\OSGeo4W64\bin\gdaljni.dll: Can’t load AMD 64-bit .dll on a IA 32-bit platform”
This is odd as I’ve removed the windows PATH to C:\OSGeo4W64\bin and substituted C:\gdallibs before restarting Tomcat.
Somehow Tomcat is still managing to find the wrong dll – perhaps a registry setting (hope not).
So I’m getting closer to the problem… David
@boscinet
Sent: 07 July 2015 12:01
To: David Lovelace
I’m sorry but I got confused.
I was thinking you have already provided logs reporting GDAL loading issue…
But that’s not the case. Maybe I have seen logs from another user for similar issue.
That said, I have this entry in my Tomcat’s catalina.2015-07-07.log. (Note that’s not a GeoServer log but a Tomcat one)
lug 07, 2015 10:49:19 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
INFORMAZIONI: GDAL Native Library loaded (version: 1.9.2)
Do you have any chance to check what is reporting your tomcat?
An unsuccessfully loading will look like this:
Jul 03, 2015 11:08:34 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Please, let me know.
Best Regards,
Daniele
On Tue, Jul 7, 2015 at 12:17 PM, David Lovelace <david@anonymised.com> wrote:
Dear Daniele,
Just checked: GDAL is working from Java on my server.
I ran >gdalinfo.bat --formats from C:\gdallibs\javainfo and GDAL lists all the supported formats including ecw.
I also ran >gdalinfo.bat on one of my ecw files and got the full file information so clearly the java-C/C++ bridge is working.
Restarting Tomcat and Geoserver (again) still fails to show up extended raster formats.
When I unpack gdal-1.9.2-MSVC2008 (rather than gdal-1.9.2-MSVC2008x64) I assume get 32 bit versions of the JNI libraries (?).
I’ve searched the console log files generated by Geoserver (geoserver.log) and can’t find any indication of failure to load any dll files.
Does this mean perhaps that Geoserver is not even trying load any of required dll/jar files?
Is there something inherently problematic in mixing running 32 bit java on a 64 bit windows OS?
Should I try again reinstalling everything from JRE onwards in 64bit and just forgetting about JAI?
(Even though Colin Henderson has managed it somehow).
All the best and thanks again. David
@boscinet
Sent: 07 July 2015 09:28
To: David Lovelace
Hi again David,
Note that the crucial part of the GDAL support in GeoServer is the JAVA <—> C/C++ bridging since GeoServer (Java) methods need to invoke GDAL (C/C++) functions. This is provided by the JNI libs.
So, once you test “gdalinfo --formats” I think that you are only testing the gdalinfo.exe, the C side which is working.
When downloading the MSCV2008 libs from geosolutions, you should see a “javainfo” folder in that archive.
Could you run gdalinfo.bat --formats from that folder? It runs a java code which basically behave as gdalinfo but using JNI.
That is where we need to look at.
If everything is ok (but I don’t think so in your case) you will get the same output of gdalinfo.exe.
Otherwise you will see what is going wrong.
Probably your Java32 is trying to load a JNI 64 resulting into a “Can’t load IA 32-bit .dll on a AMD 64-bit platform” or something similar.
Hope this helps.
Daniele
On Mon, Jul 6, 2015 at 7:33 PM, David Lovelace <david@anonymised.com> wrote:
Dear Daniele, Thank you for bearing with me on this.
I understand the point about using Geoserver-specific GDAL libraries.
I have QGIS on my server (installed via OSGeo4W) which I don’t really want to uninstall so I’ve deleted the PATH variable to the QGIS GDAL libraries, that is say “C:\OSGeo4W64\bin;” is now removed.
As well as following your advice on this thread I have also been following the procedure for 64 bit Windows Server 2008 R2 advocated by Colin Henderson in “Mastering Geoserver”. He has both JAI “true” as well as the extended raster sources including ecw - the ‘holy grail’ on his Geoserver installations! (Does he get a prize?). Henderson is using 32 bit JRE while pointing out that multiple instances of Geoserver can be deployed to overcome 2 Gb memory and other 32 bit limitations. Using his procedure I have everything working BUT NOT the raster extensions (weep) even after closely following his procedure.
I’m using jre-7u79-windows-i586.exe to install JRE,
Add variable JRE_HOME value C:\Program Files (86)\Java\jre7.
I’m using the 32/64 installation for windows: tomcat-7.0.62.zip.
As you advise, I’ve created a folder for the Geoserver-specific gdal libraries C:\gdallibs, downloaded gdal-1.9.2-MSVC2008.zip (32 bit version, I have VC++ 2008 on my system) from geo-solutions and extracted everything to C:\gdallibs.
I have included “C:\gdallibs;” in the PATH variable.
Next I installed gdal-19-1500-ecw.msi (also from geo-solutions) and copied that version of gdal_ECW_JP2ECW.dll to C:\gdallibs.
Next I add the environment variable GDAL_DRIVER_PATH and give it the value “C:\gdallibs”
I have unzipped gdal_data.zip and placed the contents into C:\gdallibs\gdal_data.
Next I add the environment variable GDAL_DATA and give it the value “C:\gdallibs\gdal_data”.
cmd>gdalinfo –formats list all the extended formats including ecw. I’ve also got GDAL to detail all the file information from one of my ecw files.
So far so good (but I’ve been here many times before!).
All the jar files from the GDAL Coverage Formats for my version of Geoserver (2.7.1.1) are in webapps/Geoserver/WEB_INF/lib.
Tomcat restarted (from windows console)
Geoserver restarted but same as before: no raster extensions other than defaults (double weep).
I could go through the whole procedure yet again in 64 bit (uninstalling JRE 32, installing JRE 64, uninstalling and reinstalling Tomcat, redeploying Geoserver, going though all the above steps with 64 bit versions) but I don’t think that’s the issue.
I must be missing some crucial step somewhere, but where?
All the best David
@boscinet
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com84…] On Behalf Of Daniele Romagnoli
Sent: 06 July 2015 09:48
To: tilia
Cc: geoserver-users@anonymised.come.net
Hi again David,
please read below…
This is my system:
Windows 8 64.
I have installed Tomcat 7.0.62, JVM 64.
I have downloaded GDAL native libs for Windows 64 from the link provided in the GeoServer documentation.
For my system, I got this one:
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.10/native/gdal/windows/MSVC2008/gdal-1.9.2-MSVC2008-x64.zip
and extracted to c:\gdallibs
Then I have installed the ECW and MrSID msi.
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.10/native/gdal/windows/MSVC2008/gdal-19-1500-x64-ecw.msi
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.10/native/gdal/windows/MSVC2008/gdal-19-1500-mrsid.msi
I have set the PATH environment variable on my tomcat setenv.bat script as PATH=c:\gdallibs
Then I have set the GDAL_DRIVER_PATH environment variable on the same script as GDAL_DRIVER_PATH=C:\Program Files\GDAL\gdalplugins
(this is where the 2 msi installers put the files by default).
Then, I have restarted GeoServer and I can see the ECW and MrSID stores as well as the LOG stating that GDAL 1.9.2 has been properly loaded.
Then I did a test. I have installed the OSGeo4W libs, updated the tomcat setenv scripts to use these libs instead of the previous ones and restarted GeoServer. As expected, No GDAL drivers are available since, as already stated in the first email, the OSGeo4W installation provides different set of libs. Note that the native libs are a bad beast. The GeoServer GDAL support is based on JNI. There is a jar file containing methods which calls native methods bridging to the underlying GDAL C/C++ libs. Using different versions of the libs (as the ones provided by OSGeo4W) doesn’t guarantee the same methods will be available and the bridging will properly work.
The libs referred by the documentation have been expressly packed to be used by GeoServer.
Please, try again with the suggested steps and let us know. I’ll be available for further clarifications.
Best Regards,
Daniele
On Fri, Jul 3, 2015 at 8:02 PM, tilia <david@anonymised.com…> wrote:
Just to say that Geoserver still fails to show non-default raster sources
despite my best efforts and the detailed advice from Daniele (thanks for
your patience BTW).
All paths and environmental variables are correct and all the required jar
files in geoserver\WEB-INF\lib
My problem seems similar to Attakorn Poonkesorn who posted recently.
OSGeo4W64 places gdal libraries in C:\OSGeo4W64\bin and this where my gdal
variables point to.
I’ve put those 4jni.dll files in there too.
The gdal_data files are in C:\OSGeo4W64\share\gdal.
gdal works perfectly from the command line.
I’ve rather run out of time on this - all I can say is that Geoserver is
very difficult to set up in anything other default mode. I’m not a java
expert - perhaps you have to be.
If anyone can come up with a fail safe explanation of how to have raster
functionality that includes ecw I’d love to know!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-and-ecw-raster-formats-tp5213620p5214253.html
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Geoserver-users@anonymised.comforge.net
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
