[Geoserver-users] GeoServer and Google's Geo Search
David
I get some errors during building the geosearch module:
[ERROR] BUILD FAILURE
Please refer to F:\my_geoserver\geoserver\community\geosearch\target\surefire-reports for the individual test results.
[INFO] Trace
org.apache.maven.BuildFailureException: There are test failures.
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:579)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:499)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:478)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:330)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:291)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:142)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:336)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
at org.apache.maven.plugin.surefire.SurefirePlugin.execute(SurefirePlugin.java:530)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:451)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:558)
… 16 more
[INFO] Total time: 5 minutes 50 seconds
[INFO] Finished at: Sun May 25 16:07:51 CEST 2008
[INFO] Final Memory: 34M/62M
The content of the surefire-report file is:
Test set: org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 5.087 sec <<< FAILURE!
testOutput(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest) Time elapsed: 2.984 sec <<< ERROR!
org.xml.sax.SAXParseException: Premature end of file.
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
at org.geoserver.test.GeoServerAbstractTestSupport.dom(GeoServerAbstractTestSupport.java:695)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:612)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testOutput(GeoSearchKMLTest.java:23)
testDataRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest) Time elapsed: 2.093 sec <<< ERROR!
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testDataRegionator(GeoSearchKMLTest.java:37)
regards
Stefan
Von: David Winslow [mailto:dwinslow@anonymised.com]
Gesendet am: Freitag, 23. Mai 2008 15:21
An: Andrea Aime
Cc: Ziegler Stefan; geoserver-users; Justin Deoliveira
Betreff: Re: [Geoserver-users] GeoServer and Google’s Geo Search
The GeoSearch module is not included in (pre-)releases; it is still a
community module. You can build it pretty easily, however. All that is
needed is to check out the most recent version of GeoServer trunk (and I
do mean most recent, the last couple of commits have improved things
greatly) and run "mvn install -Prest,geosearch’
This will produce web/target/geoserver.war which can be deployed
normally; you should probably back up your data dir just to be on the
safe side.
GeoServer by itself will provide the GeoSearch index under
http://localhost:8080/geoserver/rest/sitemap.xml (follow links therein
to see the output describe individual layers).
Additionally, if you set up a recent checkout of GeoWebCache and create
a layer with the format set to ‘geosearch-kml’ then you can point Google
Earth at
http://localhost:8080/geowebcache/service/kml/.geosearch-kml.kml
to see automatically regionated data. This requires going to the
GeoServer configuration page and specifying the attribute to use;
GeoServer will then ensure that features with higher values of this
attribute show up when Google Earth is at world-scale zoom levels and
those with lower values show up as you zoom in.
Feel free to bother me with any questions or problems; thanks a lot for
the interest!
-David
Andrea Aime wrote:
Ziegler Stefan ha scritto:
Hi
I read the blog entry about Geoserver and Google’s Geo Search and I’m
fascinated. Can I grab the 1.7 alpha version and play around or do I
need a trunk version?
You do need a trunk version as well as a community module… not
sure how the build is done for it, maybe a profile… I’ll let
Justin/David chime in and provide more details
!DSPAM:4040,4836b84c120871628642973!
Oops, looks like I neglected to run tests before committing my latest changes. I've fixed this now, so please update your checkout and run 'mvn install -Prest,geosearch' again.
Also, I forgot to mention earlier that the automated regionating code currently depends on functionality that is only provided by postgis datastores. Please keep this in mind while trying things out.
David Winslow
Ziegler Stefan wrote:
David
[INFO] Trace
... 16 more
regards
Stefan
An: Andrea Aime
Betreff: Re: [Geoserver-users] GeoServer and Google's Geo Search
greatly) and run "mvn install -Prest,geosearch'
safe side.
a layer with the format set to 'geosearch-kml' then you can point Google
Earth at
http://localhost:8080/geowebcache/service/kml/&lt;layer&gt;\.geosearch\-kml\.kml
the interest!
-David
>> Hi
>> I read the blog entry about Geoserver and Google's Geo Search and I'm
> You do need a trunk version as well as a community module... not
> sure how the build is done for it, maybe a profile... I'll let
> Cheers
> Andrea
!DSPAM:4040,48397394191285210051143!
