While upgrading to Windows 10 I installed also Java 9 from http://download.java.net/java/jdk9/archive/116/binaries/jre-9-ea+116_windows-x64_bin.exe
Geoserver does not start. I wonder how big a workload it will mean to make Geoserver to run on jre9 when the time comes.
This is the console log:
Welcome to GeoServer!
JAVA_HOME: C:\Program Files\Java\jre-9
Please wait while loading GeoServer...
WARNING: Module not found [ssl]
2016-05-04 19:01:07.020:INFO::main: Logging initialized @1245ms
2016-05-04 19:01:07.285:INFO:oejs.Server:main: jetty-9.2.13.v20150730
2016-05-04 19:01:07.307:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:/C:/ohjelmat/geoserver-2.9-RC1/webapps/] at interval 1
2016-05-04 19:01:16.106:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2016-05-04 19:01:17.727:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/C:/ohjelmat/geoserver-2.9-RC1/webapps/geoserver/,STARTING}{C:\ohjelmat\geoserver-2.9-RC1\webapps\geoserver}
java.lang.IllegalArgumentException: org.geotools.coverage.grid.GridCoverageFactory is not an ImageIO SPI class
at javax.imageio.spi.ServiceRegistry.checkClassAllowed(java.desktop@anonymised.com/ServiceRegistry.java:733)
at javax.imageio.spi.ServiceRegistry.<init>(java.desktop@anonymised.com/ServiceRegistry.java:138)
at org.geotools.factory.FactoryRegistry.<init>(FactoryRegistry.java:155)
at org.geotools.factory.FactoryCreator.<init>(FactoryCreator.java:91)
at org.geotools.coverage.CoverageFactoryFinder.getServiceRegistry(CoverageFactoryFinder.java:63)
at org.geotools.coverage.CoverageFactoryFinder.getGridCoverageFactory(CoverageFactoryFinder.java:93)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:171)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:444)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:791)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:294)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
at org.eclipse.jetty.server.Server.start(Server.java:387)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
at org.eclipse.jetty.server.Server.doStart(Server.java:354)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
at java.security.AccessController.doPrivileged(java.base@anonymised.com/Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(java.base@...7578.../Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(java.base@anonymised.com..7578.../NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(java.base@anonymised.com/DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(java.base@anonymised.com/Method.java:531)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
at org.eclipse.jetty.start.Main.start(Main.java:817)
at org.eclipse.jetty.start.Main.main(Main.java:112)
2016-05-04 19:01:17.955:INFO:oejs.ServerConnector:main: Started ServerConnector@anonymised.com{HTTP/1.1}{0.0.0.0:8080}
2016-05-04 19:01:17.960:INFO:oejs.Server:main: Started @12186ms
-Jukka Rahkonen-
