[Geoserver-users] Geoserver and Java OutOfMemoryError
Do you see legend of test:test?
-Jukka-
Luciano Martin Galletti wrote:
rebooting tomcat with:
http://localhost:8080/geoserver/ows?service=WMS&request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=topp:states
i can see legend
To: galletti77@anonymised.com; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geoserver and Java OutOfMemoryError
Date: Sun, 24 Jan 2016 20:51:25 +0000
Try first if this request works for you:
If it works the difference must be in your layer test:test and its styles and you should tell us more about the data and your SLD.
-Jukka Rahkonen-
I’m using Win 8.1 Geoserver 2.8.1 and Tomcat 7
whilw when i try now :
http://localhost:8080//geoserver/ows?service=WMS&request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=test%3Atest
Can’t obtain the schema for the required layer.
test:test layer does not exist.
