Greets:
Brand new to the list as I spend the weekend researching map servers. Here is
the scenario that I am contemplating. A group of us are going sailing down
the eastern seaboard from Canada to the Caribbean and the electronic
navigation system and charts have been acquired. All standard stuff nothing
fancy.
The problem is that in order to view the charts for planning or discussion you
need to fire up the electronic charting system which in general do not
provide good high level overviews. They are good for course planning,
tracking and route planning gps integration etc.
To overcome this problem as there are several of us onboard is to prepare a
map server that displays the NOAA BSB Raster and Vector charts as an overlay
at the appropriate zoom level of the eastern seaboard and caribbean regions.
This allows for both a high level view as well as detailed view in a
standalone application that can be used in addition too the standard
navigation packages which use the same charts. As everyone will have putters
on board and I run linux its simple to create an onboard wireless network.
So before I go down this route and spend copious amounts of time learning all
the details of charts, map servers, java, tomcat, postgis/postgresql etc I
was wondering: first is this even feasible as I see no google data
on "geosever and NOAA BSB raster or vector charts" even though both should be
supported. Secondly is there perhaps a simpler solution to creating a
functional mapserver used primarily for reviewing and displaying data in this
standard format and in a multi user environment.
Thanks for any information or insights that you may wish to share.
Best regards
/ch
