[Geoserver-users] GeoServer and OGC Compliance
Hi
On the GeoServer site it says that GeoServer is OGC compliant, but while cross referencing on the OGC site, status is marked as Implementing.
Can anyone please throw some light on this?
Given if GeoServer is not compliant and is only implementing, then what are the points that one need to work on to make it compliant.
Thanks
Hi Anunay,
I believe it varies depending on which OGC standard.
I’d assume if GeoServer says it is compliant it is. I know GeoServer is a reference implementation for a random mix of the standards too (i.e. WCS 1.x and WFS 1.0).
I agree it’s not clear which ones are compliant with what, but that’s an issue with the OGC webpage.
Jonathan
On 27 August 2013 07:49, Anunay Sinha <anunay.sinha88@anonymised.com> wrote:
Hi
Thanks
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
I can explain, you need to pay money to officially run the certification tests, and are rewarded with a cute badge for your website.
Various sponsors have paid for GeoServer to be official, you can see the badges on geoserver.org
We do run the certification tests, unofficially on our own hardware, prior to each release, and indeed as part of the nightly build:
So if you know anyone with deep pockets we would love to get a bit more bling for the website.
Jody
On Tue, Aug 27, 2013 at 4:49 PM, Anunay Sinha <anunay.sinha88@anonymised.com> wrote:
Hi
Thanks
Visit us today!
