Folks,
I've created a bunch of spatial indexes on my DB2, but still the showing of maps is rather slow: should I re-register the spatial columns, re-deploy GeoServer or do something else to make them work ?
Luca Morandini
www.lucamorandini.it
Luca Morandini ha scritto:
Folks,
I have no idea, never managed to find the time and try out db2 spatial
support. David Adler is the boss here. Hope he may know more.
I missed the original post - too much traffic on the GeoTools/GeoServer/uDig groups.
A few questions:
1. Is the drawing of the data from other sources faster - why do you think it is an index issue?
2. What are the spatial index definitions?
3. Did you do a runstats after creating the index?
db2 runstats on table <schemaName>.<tableName> and indexes all
4. How many rows are in the table?
5. How many rows are being fetched and displayed?
Folks,
A few questions:
Well, it's dog slow when it comes to drawng roads (about 29.000 rows),
and I inferred it was for the lack of indexes.
Usual grid sizes gathered from the spatial index advisor:
CREATE INDEX geostrade_si
ON geostrade(Shape)
EXTEND USING db2gse.SPATIAL_INDEX(17000,51000,0)
and so on...
Acutally not.. I supposed DB2 was lke Oracle in this... anyway, I've
done RUNSTATS to no noticeable effect.
The biggest one is roads, about 29.000 rows.
A few hundred I suppose... how can I gather this piece of informtion ?
Best regards,
Luca Morandini
Hey guys,
I have no idea about the DB2 gt2 query setup, but I did find similar symptoms resulting from the ArcSDE query setup a while ago.
The issues showed up when there was a query which selected a small number of features from a very large featurecollection. My example was a small view of a roads dataset.
Two fixes caused major speedups in my map renderings:
http://jira.codehaus.org/browse/GEOT-1007
and
http://jira.codehaus.org/browse/GEOT-1006
If the exact problems that these patches fix *do* exist in the DB2 code, (and you're using a PropertyIsLike filter, luca!) then there might be some speedups. Of course these could also be totally unhelpful too!
Just thought I'd throw in a few code-points to look at.
--saul
