[Geoserver-users] Geoserver and SQL performance
I am experiencing significant delays in rendering png8 tiles from geoserver when the data is stored in in SQL server opposed to a shapefile.
There are almost 2 million polygon objects (Ordnance Survey Vector Map Local Buildings region).
The SLD is configured only to render the buildings when zoomed right in. It can take a couple of minutes to load and sometimes needs the geoserver service to be restarted.
Any ideas?
On Thu, Oct 16, 2014 at 10:26 AM, Alvey,David (Chief Executives) <
Even if the spatial index is there, sql server might decide not to use it
if parallel queries are enabled (because the query planner is just dumb,
I'm afraid).
We added the ability to specify query hints in the data store configuration
in recent versions to basically force sql server to use the spatial index
despite the sql server query planner bad judgement
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi.
I hope this PPT will usable to you.
http://www.slideshare.net/jangbi882/foss4-g-portland-2014-jhkwunver2
It is case of rendering big size vector date by GeoServer with PostGIS.
I think page 25 will help you. There is a SQL for find slow query.
BJ Jang
2014-10-16 18:25 GMT+09:00 Andrea Aime <andrea.aime@anonymised.com>:
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-users mailing list
Open Source GIS Technical Manager / e-Cartographer
BJ Jang
Gaia3D Inc,
On Thu, Oct 16, 2014 at 10:26 AM, Alvey,David (Chief Executives) <David.Alvey@anonymised.com> wrote:
Even if the spatial index is there, sql server might decide not to use it if parallel queries are enabled (because the query planner is just dumb, I’m afraid).
We added the ability to specify query hints in the data store configuration in recent versions to basically force sql server to use the spatial index despite the sql server query planner bad judgement
Ing. Andrea Aime
@geowolf
Technical Lead
