I’m trying to use GeoServer as a service in Win 2003 as shown in
http://geoserver.org/display/GEOSDOC/Windows+Service+Wrapper
and took the suggestions of the Comments, but still get this, any ideas?
D:\OGI\Downloads\geoserver_service_wrapper>wrapper.exe -c ./bin/wrapper/wrapper.
conf
wrapper | → Wrapper Started as Console
wrapper | Launching a JVM…
jvm 1 | WrapperSimpleApp: Unable to locate the class org.mortbay.start.Main:
java.lang.ClassNotFoundException: org.mortbay.start.Main
jvm 1 |
jvm 1 | WrapperSimpleApp Usage:
jvm 1 | java org.tanukisoftware.wrapper.WrapperSimpleApp {app_class} [app_p
arameters]
jvm 1 |
jvm 1 | Where:
jvm 1 | app_class: The fully qualified class name of the application t
o run.
jvm 1 | app_parameters: The parameters that would normally be passed to the
jvm 1 | application.
wrapper | ← Wrapper Stopped
Roger Bedell, President Sylvan Ascent Inc.
800-362-8971
+34 626 855 662
roger@anonymised.com
www.sylvanascent.com
www.topodepot.com
On Sun, 2 Nov 2008 05:34:23 am Sylvan Ascent Inc. wrote:
I'm trying to use GeoServer as a service in Win 2003 as shown in
ideas?
i've been running GeoServer with JSW for quiet some time now with no
problems. from what you posted it looks like a misconfiguration of the
wrapper.conf params. i, for example have the following set in that
wrapper.conf file (running on GNU/Linux Fedora 8) --the relative paths
may differ of course depending on where this wrapper.conf file is
located on your system:
wrapper.java.classpath.1=../lib/wrapper.jar
wrapper.java.classpath.2=../start.jar
wrapper.java.additional.8=-Djetty.home=..
wrapper.app.parameter.1=org.mortbay.start.Main
wrapper.app.parameter.2=0
wrapper.app.parameter.3=org.mortbay.start.Main
wrapper.app.parameter.4=true
wrapper.app.parameter.5=1
wrapper.app.parameter.6=--stop
./bin/wrapper/wrapper. conf
wrapper | --> Wrapper Started as Console
wrapper | Launching a JVM...
org.mortbay.start.Main: java.lang.ClassNotFoundException:
jvm 1 |
{app_class} [app_p arameters]
jvm 1 |
jvm 1 | Where:
application t o run.
passed to the jvm 1 | application.
wrapper | <-- Wrapper Stopped
800-362-8971
+34 626 855 662
roger@anonymised.com <mailto:roger@anonymised.com>
www.sylvanascent.com <http://www.sylvanascent.com/>
www.topodepot.com <http://www.topodepot.com/>
cheers;
rsn
