Dear Community,
*Problem:* The Geoserver (2.8.0) which is installed in an Ubuntu 14.04 VM
stopped creating the audit logs suddenly.
*Background:* A couple of months ago I followed the instructions at
Geoserver Training - Logging all requests on Geoserver
<http://geoserver.geo-solutions.it/edu/en/adv_gsconfig/auditing.html> to
enable audit logging in Geoserver. The process was successful allowing me to
parse the logs using ElasticSearch, Logstash, and Kibana to get insights on
service usage. Reviewing the analytics recently showed no Geoserver activity
for a significant amount of time which suggested that the audit logs had
potentially a problem. I checked the audit log generation which showed that
no logs had been created for a significant amount of time (i.e. weeks).
*Audit logs configuration:*
The configuration that I included in the monitor.properties file is
following:
#Enable Audit Logging to monitor requests
audit.enabled=true
audit.path=/var/lib/tomcat7/webapps/geoserver/data/logs
audit.roll_limit=100000
The configuration that I included in the header.ftl file is following:
# start time,url,error flag,total time,response
length,services,version,operation,resources,query,response content type
The configuration that I included in the content.ftl file is following:
${startTime?datetime?iso_utc_ms},${remoteAddr!""},<#if
error??>failed<#else>success</#if>,${totalTime},${responseLength?c},${service!""},${owsVersion!""},${operation!""},${resourcesList!""},${queryString!""}",${responseContentType!""}
Has anyone had a similar issue in the past?
I appreciate your time and effort.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Audit-Logging-stopped-working-tp5284210.html
