[Geoserver-users] GeoServer behind a HTTP-Proxy
Hello,
we must solve the following connection to a WMS:
[WMS (Internet)] ---- [HTTP-Proxy] ---- [GeoServer] ---- [Clients]
How can we tell GeoServer to use the HTTP-Proxy to connect to the internet WMS server?
Yours Rüdiger
Hello Rüdiger,
very easy: Admin login ---> Global --> 4th input field is: 'Proxy Base URL'.
Enter your proxy sever and you're done.
It kills your 'Layer Preview' though as the proxy doesn't know about
Openlayers.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-behind-a-HTTP-Proxy-tp5069332p5069513.html
Hello,
I used the following URL as the getCapabilities URL:
  http://geodaten.bayern.de/ogc/ogc_dop200_oa.cgi?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetCapabilities
The http-proxy is configured as:
  http://<proxyname>:<proxyport>
But I get "connection refused" messaged while creating a WMS data source.
Opening the WMS URL with firefox and IE works through the proxy.
Any ideas?
Yours Rüdiger
Von: cmaul [mailto:Christian.Maul@…4794…]
Gesendet: Dienstag, 30. Juli 2013 01:54
An: geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] GeoServer behind a HTTP-Proxy
Hello Rüdiger,
It kills your 'Layer Preview' though as the proxy doesn't know about Openlayers.
Christian
Dr Christian Maul
Project Manager
Department of Sustainability and Environment Level13, Marland House, 570 Bourke Street Melbourne 3000
Get your SQL database under version control now!
Version control is standard for application code, but databases havent caught up. So what steps can you take to put your SQL databases under version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Start up your server with -Dhttp.proxyHost= and -Dhttp.proxyPort= and it should all work fine.
Ian
On 30 July 2013 10:42, Gubler, Ruediger <rgubler@anonymised.com> wrote:
Hello,
http://:
But I get “connection refused” messaged while creating a WMS data source.
Any ideas?
Yours Rüdiger
Von: cmaul [mailto:Christian.Maul@anonymised.com]
Hello Rüdiger,
very easy: Admin login —> Global → 4th input field is: ‘Proxy Base URL’.
Enter your proxy sever and you’re done.
It kills your ‘Layer Preview’ though as the proxy doesn’t know about Openlayers.
Christian
Dr Christian Maul
Project Manager
Ian Turton
On Tue, Jul 30, 2013 at 12:12 PM, Ian Turton <ijturton@anonymised.com> wrote:
Start up your server with -Dhttp.proxyHost=<proxyname> and
-Dhttp.proxyPort=<proxyport> and it should all work fine.
Two different types of proxies, two different configurations.
Ian is giving you the solution for a forward proxy that GeoServer might
needs to access the internet itself.
Christian is giving you directions for a reverse proxy that you might be
using to expose GeoServer to the internet,
giving it a different hostname and path
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello,
I changed the startup.bat to the following:
:run
set PROXY_OPTS=-Dhttp.proxyHost=myproxy.mycompany.lan -Dhttp.proxyPort=8080
if “%JAVA_OPTS%” == “” (set JAVA_OPTS=-XX:MaxPermSize=128m)
set RUN_JAVA=%JAVA_HOME%\bin\java
cd %GEOSERVER_HOME%
echo Please wait while loading GeoServer…
echo.
“%RUN_JAVA%” “%JAVA_OPTS%” “%PROXY_OPTS%” -DGEOSERVER_DATA_DIR=“%GEOSERVER_DATA_DIR%” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar
cd bin
goto end
But I still get “connection refused” messages.
Yours Rüdiger
Von: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Im Auftrag von Andrea Aime
Gesendet: Dienstag, 30. Juli 2013 12:25
An: Ian Turton
Cc: Gubler, Ruediger; geoserver-users@lists.sourceforge.net
Ian is giving you the solution for a forward proxy that GeoServer might needs to access the internet itself.
Christian is giving you directions for a reverse proxy that you might be using to expose GeoServer to the internet,
Ing. Andrea Aime
@geowolf
Technical Lead
