[Geoserver-users] GeoServer Blank Graphics
Hello all,
New to GeoServer, but installed it on my Windows Server 2008 R2 using the exe with IIS and got it up and running without any problems until I started to look at the open layer sample files. By default JRE 7 was installed and all I was heating was the default map window with no graphics. I did a little reading and found that the JRE 7 should be replaced with JRE 6. I replaced it with JRK 6.0_37 and was able to access the sample using the interface from localhost/geoserver/ and also www.geoiddata.com/geoserver/ from the browser on my server. The local host works correctly when I access the samples including the data table when you on a graphic. When I acces through the web URL I get the window with the graphics, but clicking on a graphic does not display the graphic. If I try to access the samples from a remote machine I just get a blank frame. I’m clueless of what the problem might be. I have tried with Chrome, IE Safari and Foxfire with the same results?
Data directory D:\Program Files (x86)\GeoServer 2.3.0\data_dir
Locks 0
Connections 4
Memory Usage 67 MB
Free memory
JVM Version Sun Microsystems Inc.: 1.6.0_37 (Java HotSpot™ Client VM)
Available Fonts GeoServer can access 365 different fonts. Full list of available fonts
Native JAI false
Native JAI ImageIO false
JAI Maximum Memory 61 MB
JAI Memory Usage 0 KB
Free memory
JAI Memory Threshold 75.0
Number of JAI Tile Threads 7
JAI Tile Thread Priority 5
ThreadPoolExecutor Core Pool Size 5
ThreadPoolExecutor Max Pool Size 10
ThreadPoolExecutor Keep Alive Time (ms) 30000
Update Sequence 78
