[Geoserver-users] GeoServer bounding boxes [SEC=UNCLASSIFIED]
Our GeoServer layer has a Native SRS = EPSG:4283 which uses Lat/Long.
EPSG:4283 = GDA94 = Geocentric Datum of Australia 1994
The Native SRS Bounding Box has a different extent to the Lat/Lon Bounding Box.
Does anyone know why if they’re both using Lat/Long?
What are the repercussions of having different lat/long coordinates for the 2 bounding boxes?
Inna
Inna
On Thu, Oct 17, 2013 at 7:11 AM, Inna Nogeste <I.Nogeste@anonymised.com> wrote:
Box.
Does anyone know why if they're both using Lat/Long?
Because they are using different datums (the ellipsoid is no the same, and
not oriented
the same way)
None that I can think of
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea, yes the different datum is what I suspected.
I am new to GeoServer - is the Lat/Lon Bounding Box in WGS84? Or which geographic projection does GeoServer use as its default?
It’s good to hear that there shouldn’t be any problems with the differences between the 2 bounding boxes as the differences are very small. Interestingly, the Min/Max X values for the 2 different bounding boxes are the same for almost all the layers but the Min/Max Y coordinates are different for nearly all the layers.
Inna
Because they are using different datums (the ellipsoid is no the same, and not oriented
the same way)
Ing. Andrea Aime
@geowolf
Technical Lead
