What is the most common way to cluster both the GeoServer instances and the PostGIS instances for high availability? The user documentation doesn't seem to indicate how to create clustered database connection pools from GeoServer to PostGIS. The examples I've seen have a single GeoServer instance pairs with a single PostGIS instance.
-Darren
Darren Hardy
Digital Library Systems & Services
Stanford University
I am not an advanced Geoserver user, but I have managed to use 2 Geoserver instances, but that is not any limit. I used Iacovella - Younblood "Geoserver's Beginners Guide" to configure a simple Geoserver cluster. I also use one PostGis instance. Using more Postgis instances may not be so easy. I think more than one database servers are needed, and every server needs a Geoserver store of it's own.
Oiva Hakala
Agrifood Research Finland
________________________________________
Lähettäjä: Darren Hardy [drh@anonymised.com]
Lähetetty: 9. elokuuta 2013 21:26
Vastaanottaja: Geoserver
Aihe: [Geoserver-users] GeoServer cluster running against PostGIS cluster
-Darren
Darren Hardy
Stanford University
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Eh, the book is Iacovella - Youngblood: "Geoserver Beginner's Guide".
Oiva
-Darren
Darren Hardy
Stanford University
This blog post by Simone explains how they did it for very high availability:
http://geo-solutions.blogspot.it/2012/08/real-world-uses-cases-troubleshooting.html
This also may be of interest - http://suite.opengeo.org/opengeo-docs/sysadmin/production/availability.html
Jonathan
On 12 August 2013 08:14, Hakala Oiva (MTT) <oiva.hakala@anonymised.com> wrote:
I am not an advanced Geoserver user, but I have managed to use 2 Geoserver instances, but that is not any limit. I used Iacovella - Younblood “Geoserver’s Beginners Guide” to configure a simple Geoserver cluster. I also use one PostGis instance. Using more Postgis instances may not be so easy. I think more than one database servers are needed, and every server needs a Geoserver store of it’s own.
Oiva Hakala
Lähettäjä: Darren Hardy [drh@anonymised.com3…]
What is the most common way to cluster both the GeoServer instances and the PostGIS instances for high availability? The user documentation doesn’t seem to indicate how to create clustered database connection pools from GeoServer to PostGIS. The examples I’ve seen have a single GeoServer instance pairs with a single PostGIS instance.
-Darren
Darren Hardy
Stanford University
It’s a free troubleshooting tool designed for production.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
