[Geoserver-users] GeoServer Clustering - Embedded Brokers
Hello,
We have set up clustering between 2 geoservers. We want to implement the “Peer-to-peer newtork with embedded brokers and shared data directory” topology.
We are using the default cluster configuration (broker.xml; cluster.properties; embedded-broker.properties). However, the geoserver.log is reporting errors like:
2016-09-21 08:10:43,834 WARN [network.DiscoveryNetworkConnector] - Could not start network bridge between: vm://3404d32d-6cd6-4ccb-a9f8-2ee428c12977?async=false&network=true and: nio://127.0.0.1:57496 due to: java.net.ConnectException: Connection refused: no further information
As a first troubleshooting step, we want to verify embedded broker is running on each server. Is there a way to verify the embedded broker is running?
Kevin
Hi Kevin,
I’m just going by memory, but believe you can simply look at the configuration page for the cluster to
check if the embedded broker is enabled? It should also be logging on the logs on startup.
However, per to peer in the default configuration requires multicast to be enabled in your network, so that nodes
can find each other. Is that the case for you?
On Wed, Sep 21, 2016 at 4:19 PM, Kevin Berger <Kevin.Berger@anonymised.com> wrote:
Hello,
Kevin
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
The GUI page indicates Embedded broker is enabled.
Logs appear to indicate broker is enabled. Getting messages like:
2016-09-21 08:02:56,277 ERROR [cluster.impl] - Started the embedded brokerURI: BrokerService[3404d32d-6cd6-4ccb-a9f8-2ee428c12977]
2016-09-21 08:02:56,277 INFO [cluster.client] - Connecting…
2016-09-21 08:02:56,277 INFO [cluster.impl] - Using brokerURI: vm://3404d32d-6cd6-4ccb-a9f8-2ee428c12977?create=false&waitForStart=5000
Although we are not sure why the Started the embedded line indicates ERROR (is this a true error; or false reprting)
As I think we can conclude embedded broker is enabled, looking at the network is our second troubleshooting step so we will investigate that angle.
Thanks for your feedback.
Kevin
Hi Kevin,
On Wed, Sep 21, 2016 at 4:19 PM, Kevin Berger <Kevin.Berger@…7691…> wrote:
Hello,
Kevin
Ing. Andrea Aime
@geowolf
Technical Lead
The ERROR line in the log is a “false error” that log should actually be a INFO.
Debugging the embedded broker is not very easy since he don’t have access
to ActiveMQ web console.
In fact you can consider the broker is correctly enable if you have something like this:
21 Sep 17:17:50 ERROR [cluster.impl] - Started the embedded brokerURI: BrokerService[f088d295-ab15-470a-a45e-bba8cc3fad8a]
21 Sep 17:17:50 INFO [cluster.client] - Connecting…
21 Sep 17:17:50 INFO [cluster.impl] - Using brokerURI: vm://f088d295-ab15-470a-a45e-bba8cc3fad8a?create=false&waitForStart=5000
21 Sep 17:17:50 INFO [cluster.client] - Registration…
21 Sep 17:17:50 INFO [cluster.client] - Impossible to register GeoServer with destination, waiting…
21 Sep 17:17:50 INFO [cluster.client] - Waiting for registration…(1/3)
21 Sep 17:17:50 WARN [TransportConnection.Transport] - Transport Connection to: tcp://127.0.0.1:58474 failed: java.io.EOFException
21 Sep 17:18:00 INFO [cluster.client] - Registration…
21 Sep 17:18:00 INFO [cluster.client] - Now GeoServer is registered with the destination
21 Sep 17:18:00 INFO [cluster.server] - Activating JMS Catalog event publisher…
Nuno Oliveira
On 09/21/2016 05:06 PM, Kevin Berger wrote:
Hi Andrea,
Kevin
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: September 21, 2016 09:31
To: Kevin Berger
Subject: Re: [Geoserver-users] GeoServer Clustering - Embedded Brokers
Hi Kevin,
Hello,
Kevin
Ing. Andrea Aime
@geowolf
Technical Lead
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
mob:   +39  333 8128928
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
Hi Nuno,
We verified that the logs match the contents as outlined below, so we will consider the brokers are correctly enabled. We will proceed to look at the network. Thanks for your feedback.
Kevin
From: Nuno Oliveira [mailto:nuno.oliveira@anonymised.com]
Sent: September 21, 2016 10:28
To: Kevin Berger; Andrea Aime
Nuno Oliveira
Hi Andrea,
Kevin
To: Kevin Berger
Hi Kevin,
On Wed, Sep 21, 2016 at 4:19 PM, Kevin Berger <Kevin.Berger@anonymised.com7691…> wrote:
Hello,
Kevin
Ing. Andrea Aime
@geowolf
Technical Lead
@nmcoliveira
Software Engineer
Hello,
As a follow-up, on the network side we have turned off the firewalls on the 2 geoservers and we are still getting the error. The error message below indicates it is trying to start a network bridge with itself - communicate between its own instanceName and localhost (127.0.0.1)). Is this expected behaviour – or should it try to start a bridge with another server instance?
We have GeoServer 2.8.2 installed with Java 8 Update 92.
Is there any other suggestions we can try? Maybe a configuration tweak somewhere?
Kevin
Sent: September 21, 2016 10:43
To: ‘Nuno Oliveira’; Andrea Aime
Subject: RE: [Geoserver-users] GeoServer Clustering - Embedded Brokers
Hi Nuno,
Kevin
Nuno Oliveira
Hi Andrea,
Kevin
To: Kevin Berger
Hi Kevin,
Hello,
Kevin
Ing. Andrea Aime
@geowolf
Technical Lead
@nmcoliveira
Software Engineer
As Andrea said “peer to peer in the default configuration requires multicast to be enabled in your network” and sometimes this is not the case.
If multicast is enabled in your network and with the firewalls deactivated I cannot think about anything else at the moment :frowning:
If nothing works I would suggest do a try with a standalone ActiveMQ.
On 09/21/2016 09:38 PM, Kevin Berger wrote:
Hello,
Kevin
Hi Nuno,
Kevin
Nuno Oliveira
Hi Andrea,
Kevin
To: Kevin Berger
Hi Kevin,
Hello,
Kevin
Ing. Andrea Aime
@geowolf
Technical Lead
@nmcoliveira
Software Engineer
@nmcoliveira
Software Engineer
I am having the same error and I was wondering if you could find a solution?
Thank you.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
