[Geoserver-users] Geoserver Clustering Issue
Hi everyone,
I am facing problems regarding clustering. I'm unable to communicate
geoserver across multiple servers. Multiple geoservers on one machine or vm
with perfect and catalog is updated when changes are made to one node. But
I'm unable to send these changes over network to other machines. Any
guidence please?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Clustering-Issue-tp5190519.html
No reply? Did i ask a wrong question?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Clustering-Issue-tp5190519p5193097.html
Question is OK but I guess that there are not so many users running Geoservers in clusters. Problem "But I'm unable to send these changes over network to other machines" makes me feel that it could have something to do with general network and firewall configuration.
-Jukka Rahkonen-
________________________________________
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Thank you for the reply. First of all i think network isn't an issue here,
I've tested my network supports multicast. Vertical clustering works well
and changes are submitted to instances running on same machine bit changes
on other machines aren't broadcasted. It has something to do with the
geoserver clustering i believe rather than general network.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Clustering-Issue-tp5190519p5193099.html
A goo search for “geoserver cluster” turns up lots of resources that describe various ways to implement clustering. Here’s a good one:
http://boundlessgeo.com/2013/04/geoserver-in-a-clustered-configuration-part-1/
On Thu, Mar 12, 2015 at 12:05 PM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com…> wrote:
Question is OK but I guess that there are not so many users running Geoservers in clusters. Problem “But I’m unable to send these changes over network to other machines” makes me feel that it could have something to do with general network and firewall configuration.
-Jukka Rahkonen-
Thank you for the reply Martin, I've followed all the tutorials and they all
lead to vertical clustering (same machine with multiple instances) none of
them explains how to achieve horizontal clustering, though geo solutilns
themselves claim horizontal clustering is possible.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Clustering-Issue-tp5190519p5193106.html
all
Yes, we have several horizontally clusted installations in production using
this module:
http://docs.geoserver.org/latest/en/user/community/jms-cluster/index.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea for getting back to me.
I have followed this JMS clustering tutorial but still unable to configure.
I'll give it a shot within a day or two again.
Meanwhile little tip/trick i would like to ask all of you, I have Apache
HTTP server on one machine which forwards my tile requests to cluster on
another machine on which 5 concurrent instances of geoservers are running
under tomcat servlet container. How can i spead up tile requests from
multiple instances? My cluster is running with the same speed as a single
server would act.
Regards
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Clustering-Issue-tp5190519p5193522.html
