[Geoserver-users] GeoServer clustering issues
Hiya geo-dudes,
Having some real show-stopper issues trying to get clustering via JMS working...
We are attempting to run 2 geoservers in a replication cluster using JMS via an external ActiveMQ broker. The geoservers are running on separate machines, and the broker is running on a third machine. Each geoserver is configured as both a Master and a Slave. Basic replication works fine, regardless of whether the catalog is changed via the GeoServer REST interface or via the GeoServer admin site. However, one use-case fails consistently:
0) Both geoserver 1 and geoserver 2 have workspaces Y and Z defined.
1) Create a layer X in workspace Y on geoserver 1.
2) Create a layer X in workspace Z on geoserver 1.
IOW, all I'm doing is creating a layer with the same name in two different workspaces. After doing this, geoserver 1's catalog is fine: two workspaces, two layers: Y.X and Z.X. However, the slave geoserver has two instances of Y.X. If I add layers WS1.LayerName, WS2.LayerName, ..., WSn.LayerName on one geoserver, the other geoserver will always have n instances of layer "LayerName" in workspace WS1.
Can anyone else reproduce this? Any suggestions?
Basic information
Version: 2.7-SNAPSHOT
Git Revision: e0d32d1c0053b786aba2aa458b3d839634d5d49a
Build Date: 26-Jul-2015 10:40
Additional jars/plugins
activemq-broker-5.9.0.jar
activemq-client-5.9.0.jar
activemq-jdbc-store-5.9.0.jar
activemq-jms-pool-5.9.0.jar
activemq-kahadb-store-5.9.0.jar
activemq-openwire-legacy-5.9.0.jar
activemq-pool-5.9.0.jar
activemq-protobuf-1.0.jar
activemq-spring-5.9.0.jar
ant-1.8.4.jar
ant-launcher-1.8.4.jar
antlr-2.7.7.jar
antlr-3.3.jar
antlr-runtime-3.3.jar
geronimo-annotation_1.0_spec-1.1.1.jar
geronimo-j2ee-management_1.1_spec-1.0.1.jar
geronimo-jms_1.1_spec-1.1.1.jar
geronimo-jta_1.0.1B_spec-1.0.1.jar
gs-control-flow-2.7-SNAPSHOT.jar
gs-jms-commons-2.7-SNAPSHOT.jar
gs-jms-geoserver-2.7-SNAPSHOT.jar
gs-printing-2.7-SNAPSHOT.jar
gs-querylayer-2.7-SNAPSHOT.jar
gs-web-wps-2.7-SNAPSHOT.jar
gs-wps-core-2.7-SNAPSHOT.jar
gt-process-geometry-13-SNAPSHOT.jar
gt-xsd-wps-13-SNAPSHOT.jar
hawtbuf-1.9.jar
itextpdf-5.4.4.jar
jms-api-1.1-rev-1.jar
jyaml-1.3.jar
mapfish-geo-lib-1.2.0.jar
metrics-core-3.0.2.jar
metrics-healthchecks-3.0.2.jar
metrics-httpclient-3.0.2.jar
metrics-json-3.0.2.jar
metrics-jvm-3.0.2.jar
metrics-log4j-3.0.2.jar
metrics-servlet-3.0.2.jar
metrics-servlets-3.0.2.jar
net.opengis.wps-13-SNAPSHOT.jar
print-lib-2.1.0.jar
serializer-2.7.1.jar
spring-jms-3.1.4.RELEASE.jar
xbean-spring-3.5.jar
xercesImpl-2.7.1.jar
xml-apis-xerces-2.7.1.jar
This should the issues:
https://osgeo-org.atlassian.net/browse/GEOS-7259
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Sep 28, 2015 at 3:45 AM, David Niedzielski
<David.Niedzielski@anonymised.com> wrote:
Hiya geo-dudes,
Basic information
ant-1.8.4.jar
antlr-2.7.7.jar
antlr-3.3.jar
hawtbuf-1.9.jar
itextpdf-5.4.4.jar
jyaml-1.3.jar
print-lib-2.1.0.jar
Geoserver-users mailing list
