[Geoserver-users] Geoserver clustering setup
I have a question regarding what is the best way to cluster Geoservers using Tomcat.
If you read GeoSolutions blog for the basic Geoserver clustering, they propose that you have one tomcat installation and you spawn multiple Geoservers instances from this one Tomcat installation. On the other hand, in the book Mastering Geoserver author proposes little different setup where you copy whole Tomcat installation and run them separately together with one Geoserver applications in each Tomcat installation.
My question is, is there any difference? Performance and stability wise?
Thank you,
Mario
On Fri, Jan 23, 2015 at 11:35 PM, Mario Miler <the.mario.miler@anonymised.com>
wrote:
using Tomcat.
<http://geoserver.geo-solutions.it/edu/en/clustering/load_balancing/tomcat.html&gt;
<http://www.amazon.com/Mastering-GeoServer-Colin-Henderson/dp/1783287691&gt;author
There should be no significant difference, the single tomcat installation
saves you some disk space
and allows you to share some configuration bits.
The important part is that each GeoServer runs in its own java process.
Or, if you feel like it, you can get most of the benefit with a single
Tomcat installation by using
the marlin rasterizer:
http://www.geo-solutions.it/blog/developerss-corner-achieving-extreme-geoserver-scalability-with-the-new-marlin-vector-rasterizer/
You'll still be somewhat more exposed to software crashes (which can be
mostly solved by having a watchdog) and
there might be other bits of GeoServer that scale less than linearly, but
the big one is, as far as I know, the
Oracle JDK own rasterizer, which marlin replaces.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you.
Yes, I am using marlin renderer on Oracle JDK but I have not seen any significant difference, at least not on low loads that I have. Supposedly marlin rendered beats Oracle only on OpenJDK which I haven tested yet because I have mixed environments (Win and Linux) and on Windows there is no official OpenJDK version (at least that I know of).
Again, thank you for you answer.
Best regards,
Mario
On Mon, Jan 26, 2015 at 12:51 PM, Mario Miler <the.mario.miler@anonymised.com>
wrote:
Thank you.
For the tests I've made it's way more effective when applied on Oracle JDK,
but it speeds up
also OpenJDK.
That said, to see the difference you need maps where you draw a significant
amount of data
(maps in which drawing is a bottleneck) or enough concurrency (at least 16
requests in parallel).
On OpenJDK it's more visible when drawing lots of data, on Oracle JDK when
the concurrency goes
up instead.
Ing. Andrea Aime
@geowolf
Technical Lead
Hmm ... interesting. I have only tested to maximum of 4 concurrent requests. Maybe that is the reason why I had no significant difference.
On 26.01.2015 14:09, Andrea Aime wrote:
For the tests I've made it's way more effective when applied on Oracle JDK, but it speeds up
also OpenJDK.
That said, to see the difference you need maps where you draw a significant amount of data
(maps in which drawing is a bottleneck) or enough concurrency (at least 16 requests in parallel).
On OpenJDK it's more visible when drawing lots of data, on Oracle JDK when the concurrency goes
up instead.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
