Hello GeoServer List,
I am using GeoServer 2.4-SNAPSHOT on Ubuntu 12.10. I am trying to correctly
render a Geotiff in Geoserver. When I do a layer preview, the data is
rendered as grey scale. I have an SLD with the appropriate color definitions
as:
<RasterSymbolizer>
<ColorMap type="ramp">
<ColorMapEntry color="#000000" quantity="0.0" opacity="0.0"/>
<ColorMapEntry color="#0000FA" quantity="1.0" opacity="0.1"/>
<ColorMapEntry color="#FA0035" quantity="30.0" opacity="0.1"/>
</ColorMap>
</RasterSymbolizer>
Transparency for the NoData Value of 0 works well, but I do not get the blue
to red color ramp that I expect. The gdalinfo output for the GeoTiff is:
Driver: GTiff/GeoTIFF
Files: pm_final_byte.tif
Size is 3600, 1800
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.100000000000000,-0.100000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Band 1 Block=3600x2 Type=Byte, ColorInterp=Gray
Min=3.393 Max=99.520
Minimum=3.393, Maximum=99.520, Mean=16.095, StdDev=8.735
NoData Value=0
Metadata:
STATISTICS_MAXIMUM=99.520126342773
STATISTICS_MEAN=16.095298841161
STATISTICS_MINIMUM=3.39302277565
STATISTICS_STDDEV=8.7346241966425
I don't know what I doing incorrectly (why I don't get my colors)
Thanks, W
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-color-ramp-doesn-t-work-for-Geotiff-tp5150350.html
