[Geoserver-users] Geoserver connection error
When i try to ask for capabilities to wfs service without security
http://localhost:8088/geoserver/Fenix/wfs?service=wfs&version=1.1.0&request=GetCapabilities
I only get a 404 Error Not found.
And the geoserver log says:
15 jul 08:50:07 WARN [servlet.PageNotFound] - No mapping found for HTTP
request
with URI [/geoserver/Fenix/wfs] in DispatcherServlet with name 'dispatcher'
where is the problem?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-connection-error-tp5151060.html
Do you have a workspace called "Fenix" with exactly that spelling and case? Is WFS enabled for this workspace? Is WFS enabled globally?
Also, the value of options in a WFS GET request is case sensitive. You must use "service=WFS" "not "service=wfs". But I do not think this is the cause in the case as you did not make it far enough to get an error.
Kind regards,
Ben.
request
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world's largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
Thanks for your answer.
Finally it works, i unistall and install it again. Is not the best solution
but it works.
Now i have another problem... when i setup the security .... :slight_smile:
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-connection-error-tp5151060p5151086.html
