I am having the same problem indicated in this thead: I have installed
Geoserver 1.7.5 and Java SE Development Kit. I followed all the installation
instructions provided in the Geosever installation manual. After I start
Geoserver and try to proceed in a browser to
http://localhost:8080/geoserver, I get the this message:
Failed to Connect: Firefox can't establish a connection to the server at
localhost:8080.
I followed a suggestion in this forum and went to the Geoserver installation
folder and found a log. It had the following information:
STATUS | wrapper | 2009/07/23 22:09:03 | The GeoServer 1.7.5 service was
not running.
STATUS | wrapper | 2009/07/23 22:09:10 | Starting the GeoServer 1.7.5
service...
STATUS | wrapper | 2009/07/23 22:09:10 | --> Wrapper Started as Service
STATUS | wrapper | 2009/07/23 22:09:10 | Java Service Wrapper Community
Edition 3.3.3
STATUS | wrapper | 2009/07/23 22:09:10 | Copyright (C) 1999-2009 Tanuki
Software, Ltd. All Rights Reserved.
http://wrapper.tanukisoftware.org
STATUS | wrapper | 2009/07/23 22:09:11 | Launching a JVM...
FATAL | wrapper | 2009/07/23 22:09:11 | Unable to execute Java command.
The system cannot find the file specified. (0x2)
FATAL | wrapper | 2009/07/23 22:09:11 | "%JAVA_HOME%\bin\java"
-Djetty.home=. -DGEOSERVER_DATA_DIR="C:\Program Files\GeoServer
1.7.5\data_dir" -Xms16m -Xmx128m -Djava.library.path="bin/wrapper/lib"
-classpath
"bin/wrapper/lib/wrapper.jar;start.jar;lib/ant-1.6.4.jar;lib/ant-optional-1.5.1.jar;lib/commons-el-1.0.jar;lib/commons-logging-1.0.jar;lib/jasper-compiler-5.5.15.jar;lib/jasper-compiler-jdt-5.5.15.jar;lib/jasper-runtime-5.5.15.jar;lib/jetty-6.1.8.jar;lib/jetty-util-6.1.8.jar;lib/jsp-api-2.0.jar;lib/log4j-1.2.14.jar;lib/servlet-api-2.5-6.1.8.jar;lib/slf4j-simple-1.0.1.jar;lib/xercesImpl-2.6.2.jar;lib/xmlParserAPIs-2.6.2.jar"
-Dwrapper.key="FqwPtxNAfmjau5jT" -Dwrapper.port=32000
-Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.pid=3220
-Dwrapper.version="3.3.3" -Dwrapper.native_library="wrapper"
-Dwrapper.service="TRUE" -Dwrapper.cpu.timeout="10" -Dwrapper.jvmid=1
org.tanukisoftware.wrapper.WrapperSimpleApp org.mortbay.start.Main
etc/jetty.xml
FATAL | wrapper | 2009/07/23 22:09:11 | Critical error: wait for JVM
process failed
ERROR | wrapper | 2009/07/23 22:09:12 | The GeoServer 1.7.5 service was
launched, but failed to start.
STATUS | wrapper | 2009/07/23 22:09:19 | The GeoServer 1.7.5 service was
not running.
I don't know what do do with this information to get Geoserver to work. I
have tried it on two computers with the same result. Can anyone help?
Jason
Gabriel Giroux wrote:
Hi;
I've installed GeoServer 1.7.3 with j2sdk 1.1 and set the environnement
variables on Win XP Pro sp3. All seems to work fine during the install and
when I'm trying to getting started with GeoServer, I get the following
error
message :
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/
*Powered by jetty:// <http://jetty.mortbay.org/>\*
I investigated to know the cause of this error, as I can see in the
GeoServer FAQ the first issue is relate to this kind of issue. But for my
case I'm ussing Firefox 3.0.9 browser and the firewall is configured.
So I tried first the url provided with the default install to log to the
server, but unfortunately it doesn't work because firefox failing to
connect
to the localhost. So I've edited the GeoServer configuration file
(jetty.xml) to change the port of connection to the host server because
the
first one used by default was used by another web server. So I changed the
connection port to 8081 and when I run the connection I get the http error
404 mentionned previously.
What I'm doing wrong , can anybody help me ???
Thank you for your help
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensign option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
View this message in context: http://www.nabble.com/GeoServer-could-not-connect-to-localhost-after-install-tp23258780p24637640.html
