Hi List,
I have a problem with the seeding process of some image data.
I run a Linux OS and GeoServer as server support. It takes 256 MB space for
image opertation and I get this error from tilecache:
File "./tilecache_seed.py", line 9, in ?
TileCache.Client.main()
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Client.py", line 108, in
main
seed(svc, base, layer, map(int, sys.argv[3:5]), map(float,
sys.argv[5].split(",")))
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Client.py", line 92, in seed
svc.renderTile(tile)
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Service.py", line 138, in
renderTile
data = layer.render(tile)
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Layer.py", line 411, in
render
return self.renderTile(tile)
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Layers/WMS.py", line 29, in
renderTile
tile.data, response = wms.fetch()
File "/srv/www/cgi-bin/tilecache_sh/TileCache/Client.py", line 64, in
fetch
raise Exception("Did not get image data back. \nURL: %s\nContent-Type
Header: %s\nResponse: \n%s" % (self.url(), ctype, data))
Exception: Did not get image data back.
URL:
http://localhost:8081/geoserver/wms?layers=CGISTMS%3ASH25T&styles=&service=WMS&width=256&format=image%2Fpng&request=GetMap&height=256&srs=EPSG%3A25832&version=1.1.1&bbox=32600360.0%2C6060000.0%2C32601000.0%2C6060640.0
Content-Type Header: application/vnd.ogc.se_xml
Response:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.OutOfMemoryError: Java heap space
Java heap space
Details:
org.geoserver.platform.ServiceException: java.lang.OutOfMemoryError: Java
heap space
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1177)
at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
"tilecache_seed.py.out" 109L, 8909C
I don't know why, because I have give a amount of 600 MB memory to the
GeoServer and same things will happend.
Maybe not the tilecache will force this problem, could it be. Further the
geoserver crashes by production of some fetched image data?
Edit: I have additionally posted this massage in the tilecache forum, so i
don't know how of both, GeoServer or tilecache force this problem
Has anyone a idea what the problem could be, or a tip where I could search
for this crashes
Thanks a lot,
Klaus
View this message in context: http://www.nabble.com/GeoServer-crash-by-tilecache-seeding-tp19370310p19370310.html
