Hi Jody, that appears to have worked Ok (It generates two LineSymbolizers), thanks heaps for pointing that out.
Mark
Regards
Mark Cupitt
“If we change the world, let it bear the mark of our intelligence”
See me on Open StreetMap
See me on LinkedIn
See me on StackExchange
The contents of this email are intended only for the individual(s) to whom it is addressed and may contain
confidential or privileged information. If you are not the intended recipient, you must not disclose, copy, distribute,
or use the contents of this email. If you have received this email in error, please notify the sender immediately and
delete the email and any attachments.
On Wed, Jun 25, 2014 at 7:42 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I don’t think you did that correctly - you were trying to provide two expressions right - for different z-indexs? So keep using two expressions:
stroke: [recode(highway, ‘motorway’, ‘#000000’)], [recode(highway, ‘motorway’, ‘#4169E1’)]
Jody Garnett
On Wed, Jun 25, 2014 at 8:33 PM, Mark Cupitt <markcupitt@anonymised.com> wrote:
Hi Jody,
FYI, I tried the recode function, it is excellent, however, it does not reproduce this
stroke: #000000, #4169E1;
using …
stroke:[
recode(highway,
‘motorway’, ‘#000000, #4169E1’
Which is sad … that would be killer …
Mark
Regards
Mark Cupitt
See me on LinkedIn
On Wed, Jun 25, 2014 at 5:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I suppose I am just confused about the use of z-index there - I usually use a z-index 1 or 2 (and then only if needed based on funny overlapping - like simulating line casing, or ensuring that a polygon outline is drawn separately overtop of the fill).
I recommend trying very simple examples like this and reviewing the SLD that is produced.
Jody Garnett
On Wed, Jun 25, 2014 at 2:42 PM, Mark Cupitt <markcupitt@anonymised.com> wrote:
Hi Jody, in thinking through your remarks, in my last response would this be a better approach to the example I gave?
[landuse=‘forest’][@scale>60000][@scale<100000]{
fill-size: 20px;
[landuse=‘forest’][@scale<60000]{
fill-size: 30px;
[landuse=‘commercial’][@scale<1000000] {
z-index: 40;
stroke: #5F9EA0;
fill: #87CEFA, url(“http://icons.markware.net/geoserver/icons/img/areas/commercial.png”);
stroke-width: 0.5px;
fill-opacity: 0.75;
label: [name];
font-size: 10px;
font-fill: #000000;
[landuse=‘forest’]{
z-index: 30;
stroke: #CBEBB6;
fill: #CBEBB6, url(“http://icons.markware.net/geoserver/icons/img/areas/forest.png”);
Regards
Mark
