[Geoserver-users] GeoServer custom authentication configuration
We want to set up custom user authentication for GeoServer. Our custom authentication is stored in Oracle tables. We have been able to set up a JDBC connection to the Oracle database. We note that by default, tables called USERS, USER_PROPS, GROUPS, and GROUP_MEMBERS are created. Is there a way to hook our custom tables to the Geoserver authentication?
Thanks.
Kevin
Look for
rolesddl.xml
rolesdml.xml
usersdml.xml
usersddl.xml
after creating a JDBC role store or a JDBC user store. The files should be in your GEOSERVER_DATA_DIR
Feel free to adapt the statements, you can ignore the *ddl.xml files, put your focus on the *dml.xml files. To be sure, grant geoserver read only access to your tables.
Christian
On Wed, Jun 8, 2016 at 4:25 PM, Kevin Berger <Kevin.Berger@anonymised.com7691…> wrote:
Thanks.
Kevin
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
