Hi Alessio,
Sorry, I didn't see your reply earlier.
I have the rest.properties file in my upgraded geoserver_data_dir, and it is identical
to the one that is automatically created in a new 2.4 geoserver_data_dir.
Are there any other config files I may be missing?
Chris
On 13/11/2013 13:08, Alessio Fabiani wrote:
I guess you need to update the rest.properties file inside the GEOSERVER_DATA_DIR. This file controls the Rest access constraints.
http://docs.geoserver.org/latest/en/user/security/rest.html
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Wed, Nov 13, 2013 at 1:45 PM, Chris Morgan <chris@anonymised.com <mailto:chris@anonymised.com>> wrote:
Hi list,
I have a GEOSERVER_DATA_DIR that I have upgraded from V2.0
to V2.4.0. Any attempt to access http://localhost:8080/geoserver/rest
gives a 404 error.
If I remove my data dir and use the default in the WAR file,
then http://localhost:8080/geoserver/rest works OK.
This leads me to the assumption that the upgrade process is
not enabling REST correctly.
What do I need to modify in my upgraded data dir to enable REST?
Chris
____________________________________________________________
Chris Morgan
Director of Information Technology
Lynx Information Systems Ltd
Tel: +44 (0)20 8780 2634 <tel:%2B44%20%280%2920%208780%202634>
Email: chris@anonymised.com <mailto:chris@anonymised.com>
Web: http://www.lynxinfo.co.uk
93-99 Upper Richmond Rd
London SW15 2TG
United Kingdom
Email: lynx@anonymised.com <mailto:lynx@anonymised.com>
Fax: +44 (0)20 8780 0931 <tel:%2B44%20%280%2920%208780%200931>
Registered in England Number 2454130
VAT Number GB 561 8979 88
Incoming and outgoing emails are checked for viruses
by Sophos AntiVirus.
This email may contain confidential information which is
intended for the named recipient(s) only. If you are
not the named recipient you should not take any action in
relation to this email, other than to notify us that you
have received it in error.
DreamFactory - Open Source REST & JSON Services for HTML5 & Native
Apps
OAuth, Users, Roles, SQL, NoSQL, BLOB Storage and External API Access
Free app hosting. Or install the open source package on any LAMP
server.
Sign up and see examples for AngularJS, jQuery, Sencha Touch and
Native!
http://pubads.g.doubleclick.net/gampad/clk?id=63469471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
<mailto:Geoserver-users@lists.sourceforge.net>
London SW15 2TG
United Kingdom
