Rahkonen Jukka (MML) wrote
I made a very quick test and the result looks promising:
1) Install Geoserver 2.8 on Windows with the binary-zip alternative
2) Test that Geoserver is running and then stop the server
3) Download Jetty from
http://eclipse.org/downloads/download.php?file=/jetty/stable-9/dist/jetty-distribution-9.3.3.v20150827.zip&r=1
4) Unzip Jetty
5) Copy directory "geoserver" from the webapps of default 2.8 installation
into webapps of Jetty 9.3.3
6) Start Jetty 9.3.3 from the installation directory with "java -jar
start.jar"
7) Check that Geoserver is available at localhost:8080/geoserver
8) Check from server status that data_dir is at
jetty933\webapps\geoserver\data and stop the server
9) From command window do "SET GEOSERVER_DATA_DIR=c:\data\test_data_dir"
10) Start Jetty 9.3.3 from the installation directory with "java -jar
start.jar"
11) Check from server status that data_dir is at c:\data\test_data_dir"
Now Geoserver 2.8 is running on Jetty 9.3.3 and it is using the data_dir
that I pointed it to use. Everything seems to work in the user interface
and for the services but I have not tested very much yet because I reacted
to your mail that you sent 50 minutes ago.
-Jukka Rahkonen-
Thank's Jukka for your work.
BUT: I'm running jetty9 in a working environment on Ubuntu - not Windows.
step5 is interesting: Copy directory "geoserver" from the webapps of default
2.8 installation into webapps of Jetty 9.3.3
i only copied geoserver.war as written in the geoserver documentation.
Now i did was you told me and got
java.lang.RuntimeException: java.io.FileNotFoundException:
/opt/jetty/jetty9/webapps/geoserver/data/logs/geoserver.log (Datei oder
Verzeichnis nicht gefunden) at
org.geoserver.web.admin.LogPage$2$1.respond(LogPage.java:130) at
org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at
org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at
org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at
org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808) at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at
at
at
org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at
at
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87) at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:553)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at
org.eclipse.jetty.server.handler.IPAccessHandler.handle(IPAccessHandler.java:220)
at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499) at
org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310) at
org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at
org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:745) Caused by:
Verzeichnis nicht gefunden) at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:146) at
org.geoserver.web.admin.LogPage$2$1.respond(LogPage.java:123) ... 96 more
but the log directory exists:
cd /opt/jetty/jetty9/webapps/geoserver/data
jetty@anonymised.com:~/jetty9/webapps/geoserver/data$ ls -la
total 28
drwxrwxr-x 6 jetty jetty 4096 Oct 14 16:15 .
drwxrwxrwx 4 jetty wambacher 4096 Oct 14 16:06 ..
-rw-rw-r-- 1 jetty jetty 1577 Oct 14 16:06 gwc-gs.xml
drwxrwxr-x 2 jetty jetty 4096 Oct 14 16:06 gwc-layers
drwxrwxr-x 2 jetty jetty 4096 Oct 14 16:15 logs
drwxrwxr-x 8 jetty jetty 4096 Oct 14 16:15 security
drwxrwxr-x 2 jetty jetty 4096 Oct 14 16:06 styles
Then i created an empty log-file but nothing is written there.
Good news: the data-dir is now at /opt/jetty/jetty9/webapps/geoserver/data,
which is much much better than before.
Bad: After changing the environment var GEOSERVER_DATA_DIR to
/opt/geoserver/geoserver_data nothings changed. No Log, no errors, old data
dir (/opt/jetty/jetty9/webapps/geoserver/data), but geoserver is running.
Question: Have i to copy /opt/jetty/jetty9/webapps/geoserver/data to my
target /opt/geoserver/geoserver_data or not? tried both: empty
geoserver_data and copied one. No different.
I think, i can live with the current situation. data is on a well defined
place. before that it was in temp-dirs changing with every restart of jetty.
Regards
walter
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-changing-data-directory-using-geoserver-war-with-jetty-tp5230038p5230151.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
