Is this the relevant connector config for Tomcat 5.5 server.xml?
http://tomcat.apache.org/tomcat-5.0-doc/config/http.html
It looks like two attributes are needed assuming you wish to add additional
mimetypes:
"compressableMimeType": The value is a comma separated list of MIME types
for which HTTP compression may be used. The default value is
text/html,text/xml,text/plain.
*** Does it make sense to add KML 'application/xml'? Perhaps others?
"compression": The Connector may use HTTP/1.1 GZIP compression in an attempt
to save server bandwidth. The acceptable values for the parameter is "off"
(disable compression), "on" (allow compression, which causes text data to be
compressed), "force" (forces compression in all cases), or a numerical
integer value (which is equivalent to "on", but specifies the minimum amount
of data before the output is compressed). If the content-length is not known
and compression is set to "on" or more aggressive, the output will also be
compressed. If not specified, this attribute is set to "off".
<Service name="Catalina">
<Connector
port="80" maxHttpHeaderSize="8192"
URIEncoding="UTF-8"
maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
enableLookups="false" redirectPort="8443" acceptCount="100"
connectionTimeout="20000" disableUploadTimeout="true"
compression="on"
compressableMimeType="text/html,text/xml,text/plain,application/xml"
Nice! Xml throughput is way faster.
Randy
-----Original Message-----
From: geoserver-devel-bounces@lists.sourceforge.net
[mailto:geoserver-devel-bounces@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Friday, August 04, 2006 12:21 PM
To: Paul Ramsey
Cc: geoserver-devel@lists.sourceforge.net; Jesse Eichar
Subject: Re: [Geoserver-devel] GZip
Paul Ramsey wrote:
It appears to be free-as-in-beer, not free-as-in-speech.
Ah, right, didn't look closely enough.
You could take your (evil) GML2-GZIP approach and do it right, by
interrogating the HTTP headers, seeing if the client is requesting
Content-encoding: gzip, and then giving them what they ask for. And
then you can remove the silly format type from the capabilities too
But then I suppose there is a danger of starting to fight with the
container, double-compressing, etc, which is why it's best to just let
the container do it...
Cool. I'm fine with that, clients can just choose to use or ignore the
gml2-gzip option as they'd like. If we ever switch embedded servlet
containers back to tomcat I'll look to add the default option. I would
imagine the servlet container would be smart enough to figure out if the
content type is already gzipped and not double compress, but then again
I imagined Jetty would support gzip output.
C
P
On 4-Aug-06, at 11:07 AM, Chris Holmes wrote:
Hmmmm... Can't seem to find any reference to jetty supporting it.
The only thing that seems to be there is an option to have it do gzip
mime-types on content types that are already gzipped. Also found
this: http://www.thomas-bayer.com/gzip-compression-filter.htm which is
a servlet filter that looks like it handles the whole negotiation. If
we used it it looks like we'd get gzip compression by default.Chris
Chris Holmes wrote:
Paul Ramsey wrote:
A couple notes, for the history file:
- Jesse has found that using gzip compression makes a huge
difference to the user experience working with WFS data sources.
- TomCat does not ship with gzip compression enabled by default, but
it does support it. The magic configuration incantation should be
prominently part of the geoserver tomcat deployment instructions.
(Jesse?)Cool, added it here:
http://docs.codehaus.org/display/GEOSDOC/GeoServer+in+Production+Environment
Jesse, could you add a bit about how to set the option in tomcat?
- Jetty may or may not support it, but if it does, it should be
turned on by default.I'll look in to making it the default with Jetty, I imagine it should
be possible.
Also note that GeoServer supports GML2-GZIP as an output format,
where GeoServer will do the gzipping for you. I think I remember
Paul thinking we should just leave it to the servlet container, but I
felt there was no harm in doing both.
But you could have uDig look for GML2-GZIP as an output format on
servers, and I think others may support it as well. Then it would
get better performance in cases where people forget to configure
their servers.
best regards,
ChrisThe compression negotiation protocol in HTTP ensures that clients
that don't support it (don't ask for it as part of their request
header) don't get it, so there is *no* downside to turning it on.(09:42:33) Paul Ramsey: Because widening the windows (max
compression) would make it even better.
(09:42:40) Jody Garnett: indeed
(09:42:44) Paul Ramsey: But that's probably not what is the default
when you turn on compression on a web server.
(09:43:06) Paul Ramsey: Oh, the whole gzip thing should be added to
the geoserver docs.
(09:43:13) Paul Ramsey: Because it's a tomcat configuration item.
(09:44:01) Paul Ramsey: Does the little bundled http server w/
geoserver do compression?
(09:44:23) Jody Garnett: good question for their devel list - I am
not sure
Join SourceForge.net's Techsay panel and you'll get the chance to
share your
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
share your
!DSPAM:1003,44d38a98262431995013331!--Chris Holmes
The Open Planning Project
http://topp.openplans.org
<cholmes.vcf>
share your
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV___
____________________________________________
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1003,44d38f09324491971556521!
Chris Holmes
