Hi Vincent,
your question is more appropriate to the geoserver-users mailing so redirecting the conversation there.
This link may be of help: <http://docs.codehaus.org/display/MAP/Building+A+Web+App>
Vincent2009 wrote:
Hi ALL,
I’m studying how to implement “search” function based on Gerserver. But I
suffered server problems as follow. Before I posted my questions, I had
searched the forum without helpful responds. 1. The Syntax of CQL. Though there is a guideline about CQL on the website,
it doesn’t provide enough in my views. My questions: how to filter by a
street name (a string, like “E 66th St”)? In the tiger-ny map, the CQL
filer: tiger_roads.NAME "is" E 66th St, but it is wrong. 2. I just want to develop “map search” like Google map, MS Live map, as my
further study platform. Unluckily, I don’t know how to start the work. Could
you give some cues or steps? Of course, if there are some examples, it
should be better.
Vincent
Gabriel Roldan
OpenGeo - http://opengeo.org
Hi Vincent. Try using the operator +=+ instead of “is” in your CQL. Works for me using a Network Link in Google Earth.
More examples here:
http://geoserver.org/display/GEOSDOC/Common+Query+Language+(CQL)+Tutorial+(unfinished)
Regards
Irfon
On Tue, May 12, 2009 at 8:47 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Vincent,
Vincent2009 wrote:
Hi ALL,
- The Syntax of CQL. Though there is a guideline about CQL on the website,
filer: tiger_roads.NAME “is” E 66th St, but it is wrong.
- I just want to develop “map search” like Google map, MS Live map, as my
should be better.
Vincent
Gabriel Roldan
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
