Beate Stollberg ha scritto:
I would like to send a GetFeature POST request using my own code.I tried the WFS_getFeature sample as it is:
but it does not work.
What am I doing wrong?
Hum, this is the second report of this kind of issue in two days,
so I raised its priority and handled it right away.
So, the issue here is that the POST request is getting handled
as a GET request if the content type is "application/x-www-form-urlencoded", assuming the request was sent
from a browser using a form.
This is a result of fixing http://jira.codehaus.org/browse/GEOS-441.
The proper content type for wfs request seems to be "application/xml" instead. The following code works:
url = new URL("http://localhost:8080/geoserver/wfs"\);
conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("POST");
conn.setRequestProperty("Content-Type", "application/xml");
conn.setUseCaches(false);
conn.setDoInput(true);
conn.setDoOutput(true);
Wheter this is right or not, hum, I'm not sure...
Here is the old discussion about this:
http://www.nabble.com/POST-once-more-tf2699315.html#a7530541
Hope this helps.
Andrea Aime
