[Geoserver-users] Geoserver does not start anymore:A valid WFS object must be provided
Hi
I have a Geoserver 2.1 instance running for years without problems. Suddently this has stopped working. If I try to start it from the tomcat manager, start process fails and in the logs I have:
Could not instantiate bean class [org.geoserver.wfs.response.CSVOutputFormat]
A valid WFS object must be provided in order for this class to work
It happears just after layer loading.
There should be a Layer that fails or something like this but I have no idea about how to fix this.
Any suggestions?
Thanks a lot!
On Mon, Aug 26, 2013 at 2:54 PM, Pierluigi Santin Fintel <
p.santin@anonymised.com> wrote:
Hi
Any suggestions?
Searching the internet I see this issue has been reported a couple of times
in the past, but
we never managed to figure out what was causing it...
However, it seems to be a service configuration problem, not a data
problem... do you have anything else in the
logs before that?
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
No nothing else that helps me.
There should be a way to at least detect which is the failing WFS and then (manually?) delete it?
Inviato: lunedì 26 agosto 2013 15:31
On Mon, Aug 26, 2013 at 2:54 PM, Pierluigi Santin Fintel <p.santin@…4543…> wrote:
Hi
Any suggestions?
Searching the internet I see this issue has been reported a couple of times in the past, but
we never managed to figure out what was causing it…
However, it seems to be a service configuration problem, not a data problem… do you have anything else in the
logs before that?
Ing. Andrea Aime
@geowolf
Technical Lead
Tai....berisik
Sent from my AXIS Worry Free BlackBerry® smartphone
-----Original Message-----
From: Pierluigi Santin Fintel <p.santin@...4543...>
Date: Mon, 26 Aug 2013 13:32:33
To: Andrea Aime<andrea.aime@...1107...>
Cc: geoserver-users@lists.sourceforge.net<geoserver-users@lists.sourceforge.net>
Subject: [Geoserver-users] R: Geoserver does not start anymore:A valid WFS
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
