Hi ,
Geoserver does not start, no logs, it simply stops at jetty initialization
(only port 8079 is open).
Below is what is being shown in my console.
Does anyone have any idea?
root@anonymised.com:~/geoserver-2.6.2/bin# ./startup.sh
GEOSERVER_HOME environment variable not found, using current
location. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /root/geoserver-2.6.2/bin/../data_dir
2015-03-06 13:01:32.027::INFO: Logging to STDERR via
org.mortbay.log.StdErrLog
2015-03-06 13:01:33.183::WARN: Deprecated configuration used for
/root/geoserver-2.6.2/webapps
2015-03-06 13:01:33.226::INFO: jetty-6.1.8
Marcelo
View this message in context: http://osgeo-org.1560.x6.nabble.com/geoserver-does-not-start-tp5192296.html
