Hi everybody,
Someone knows where could I find the list of environment variables like ${GSUSER,geoserver}.
My version of Geoserver is 2.4.4
Kamardine
Hi everybody,
Kamardine
On Fri, Feb 6, 2015 at 3:21 PM, Kamardine YOUSSOUFA <
Kamardine.YOUSSOUFA@anonymised.com> wrote:
Hi everybody,
You mean for the impersonation code paths?
http://docs.geoserver.org/stable/en/user/data/database/sqlsession.html#data-sqlsession
As far as I can see you also have any variable that was put in the &env=...
KVP parameter
(thus, usable only in GET requests), and, strictly limited to the WMS
GetMap calls, also
the following ones (I'm going to paste a code snipped here):
public static void setupEnvironmentVariables(WMSMapContent mapContent) {
// setup some SLD variable substitution environment used by
rendering transformations
EnvFunction.setLocalValue("wms_bbox",
mapContent.getRenderingArea());
EnvFunction.setLocalValue("wms_crs", mapContent.getRenderingArea()
.getCoordinateReferenceSystem());
EnvFunction.setLocalValue("wms_srs",
mapContent.getRequest().getSRS());
EnvFunction.setLocalValue("wms_width", mapContent.getMapWidth());
EnvFunction.setLocalValue("wms_height", mapContent.getMapHeight());
try {
double scaleDenominator = mapContent.getScaleDenominator(true);
EnvFunction.setLocalValue("wms_scale_denominator",
scaleDenominator);
} catch (Exception e) {
LOGGER.log(
Level.SEVERE,
"Failed to compute the scale denominator,
wms_scale_denominator env variable is unset",
e);
That said, the above snippet is valid for GeoServer 2.6.x, it's may not be
available in 2.4.x
(these variables were added to support certain types of rendering
transformations)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sorry, but in fact, I just want to know if exist an other variable like GSUSER which can contains a parameter past on request URL.
I would want to use this variable in a sql script of session startup to customize the managing of authorizations on database level.
Thanks.
Kamardine,
De : andrea.aime@anonymised.com andrea.aime@anonymised.com de la part de Andrea Aime <andrea.aime@anonymised.com1107…>
Envoyé : vendredi 6 février 2015 18:40
À : Kamardine YOUSSOUFA
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] Geoserver environment variables ?
On Fri, Feb 6, 2015 at 3:21 PM, Kamardine YOUSSOUFA <Kamardine.YOUSSOUFA@anonymised.com> wrote:
Hi everybody,
As far as I can see you also have any variable that was put in the &env=… KVP parameter
(thus, usable only in GET requests), and, strictly limited to the WMS GetMap calls, also
the following ones (I’m going to paste a code snipped here):
// setup some SLD variable substitution environment used by rendering transformations
EnvFunction.setLocalValue(“wms_bbox”, mapContent.getRenderingArea());
EnvFunction.setLocalValue(“wms_crs”, mapContent.getRenderingArea()
EnvFunction.setLocalValue(“wms_srs”, mapContent.getRequest().getSRS());
EnvFunction.setLocalValue(“wms_width”, mapContent.getMapWidth());
EnvFunction.setLocalValue(“wms_height”, mapContent.getMapHeight());
try {
EnvFunction.setLocalValue(“wms_scale_denominator”, scaleDenominator);
LOGGER.log(
Level.SEVERE,
“Failed to compute the scale denominator, wms_scale_denominator env variable is unset”,
e);
That said, the above snippet is valid for GeoServer 2.6.x, it’s may not be available in 2.4.x
(these variables were added to support certain types of rendering transformations)
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 9, 2015 at 6:40 PM, Kamardine YOUSSOUFA <
Nope, I've listed all the ones that are currently available in my previous
answer.
Ing. Andrea Aime
@geowolf
Technical Lead
