I’m trying to add a layer that is hosted by a ERDAS-Apollo WFS server. I can create the Datastore and see the available data sets just fine, however when I go to publish one of the layers it error’s out with the following message:
Caused by: org.geotools.data.DataSourceException: No XSDElementDeclaration found for {http://www.ionicsoft.com/wfs}DDMS_SMARTS
at org.geotools.data.wfs.v1_1_0.parsers.EmfAppSchemaParser.parseFeatureType(EmfAppSchemaParser.java:296)
at org.geotools.data.wfs.v1_1_0.parsers.EmfAppSchemaParser.parse(EmfAppSchemaParser.java:210)
at org.geotools.data.wfs.v1_1_0.parsers.EmfAppSchemaParser.parseSimpleFeatureType(EmfAppSchemaParser.java:123)
at org.geotools.data.wfs.v1_1_0.WFS_1_1_0_Protocol.issueDescribeFeatureTypeGET(WFS_1_1_0_Protocol.java:803)
at org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getSchema(WFS_1_1_0_DataStore.java:217)
at org.geotools.data.wfs.v1_1_0.WFSFeatureSource.(WFSFeatureSource.java:69)
at org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getFeatureSource(WFS_1_1_0_DataStore.java:456)
at org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getFeatureSource(WFS_1_1_0_DataStore.java:102)
at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:158)
at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:293)
at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:46)
at org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:327)
at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:295)
Based on my understanding, Geoserver can’t figure out what to do with DDMS_SMARTS. But I don’t control this server, it is external to me, I just need the data upon request. So, what can I do?
Here’s the URL for the WFS, you’re welcome to give it a try:
http://egeoint.nrlssc.navy.mil/erdas-apollo/vector/smtsoscmetadata?service=WFS&request=GetCapabilities
Mark
OK, I figured this out. Deep in the log files there was a SSL certificate error that caused the server to not be able to download the schema for this WFS. The solution would have been faster but I didn’t realize that GeoServer came with it’s own JVM so I was updating the root certificate file in my default java install. After I found the separate JVM it was easy enough to update the cacerts file. Once this was done the problem was solved.
To: “Geoserver-users@anonymised.comorge.net” Geoserver-users@lists.sourceforge.net
Sent: Thursday, July 18, 2013 11:54 AM
Subject: [Geoserver-users] [Geoserver] Error adding WFS Layer
Mark
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
