Ciao Hakala,
please, find my answers inline below...
Simone Giannecchini
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Dec 8, 2014 at 1:16 PM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com> wrote:
Hi
Our Geoserver was, again, out of service. Version 2.3.1 on Ubuntu 12.04
server. I found several Java heap space errors, similar as below. Heap size
is alrady 512.
512M is not that much, generally speaking.
I would settle for something between 1G and 2G.
2014-12-05 12:05:44,042 ERROR [geoserver.ows] -
java.lang.OutOfMemoryError: Java heap space
We would need a larger portion of the logs + more info about how you
use geoserver.
A memory dump might help. Check this page on how to get a memory dump
from a live geoserver:
http://docs.geoserver.org/latest/en/user/production/troubleshooting.html#using-jdk-tools-to-get-stack-and-memory-dumps
Then this flushedPos error
2014-12-05 12:38:26,552 ERROR [geoserver.ows] -
java.lang.IndexOutOfBoundsException: pos < flushedPos!
This is not a problem, it is a client that kills the connection while
geoserver is writing on the output stream.
In the more recent version this warning can be ignored setting QUIET
logging level.
And after restart this kind of warn and error. We have installed 2.3 over
2.2 so may be somethin to do with that?
2014-12-08 13:46:30,655 WARN [geoserver.security] -
/data/data_dir/security/config.xml.2.2.x could be removed manually
2014-12-08 13:46:31,288 ERROR [geoserver.security] - Error loading filter:
guiException
This looks like an harmless warning, unless you are experiencing
failuers related to security, like not being able to log in and so on.
In spite of my several notices, our sys admin still has java 7 (64-bit) on
the server. Is that the reason for heap size errors
JVM Version Oracle Corporation: 1.7.0_01 (Java HotSpot(TM) 64-Bit Server
VM)
I don't think so. You should be fine with Java 7.
Geoserver is still using Jetty.
So, what to do to prevent those errors?
Oiva Hakala, MTT, Finland
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
