[Geoserver-users] GeoServer Evaluation
Hi All !
I have to make an evaluation about GeoServer. That’s why I need your help. If you have some times to complete this array…
Thank you.
Best regards.
Licence
Compliance with WMS
What is the version of WMS supported by your product: is it compliant or just an implementation?
What are the requests not supported?
Is the GET request supported?
Is the POST request supported?
Is the SOAP request supported?
Compliance with SLD
Is the GeoSYM symbology supported?
Is the S52 symbology supported?
Is the APP-6 symbology supported?
Is the MIL2525B symbology supported?
Coordinates system supported
Is UTMs, Arc, WGS84 supported?
Geodesic parameter database supported (EPSG, GeoDEF)?
What are the output formats supported
JPEG
GIF
SVG
PNG
Others
What is the input format supported
RASTER
Digest A (ASRP/USRP)
RPF (CADRG)
geotiff
NSIF
HCRF
JPEG2000
DTED
WMS
SGBDR
others formats
VECTOR
Shapefile
VPF (VMAP, DNC)
VRF (AML)
S57 (AML, ENC)
GML2/3
WFS
SGBDR
others formats
3D
NetCDF
WCS
GRIB
others formats
Performances
Complexity of deployment
Plateform supported
Incompatibility with any client
Compliance with WFS
What is the version of WFS supported by your product: is it compliant or just an implementation?
Compliance with Filter Encoding
Virginie Berre / Ingénieur étude et développement
Générale d’Infographie
ZA Les Erables – Bâtiment 4
66, route de Sartrouville – 78232 LE PECQ Cedex
Tél. : (33) (0)1.30.15.40.50 – Fax : (33) (0)1.30.15.40.60
mailto:vberre@anonymised.com
http://www.generale-infographie.fr/
Virginie BERRE wrote:
Hi All !
Sure. Though my email client seems to lose the nice formatting.
Thank you.
Best regards.
Licence
GPL
Compliance with WMS
1.1.1 compliant (just got the OGC to update their site, see: http://www.opengeospatial.org/resource/products/ for official lists of what's compliant)
All requests are supported.
Yes.
Yes.
No, SOAP is part of 1.3
Compliance with SLD
The only SLD functionality not supported is RemoteWFS. All other user defined and post and all that is supported.
I'm pretty sure if the full SLD spec is supported (which it is in geoserver), then it's sufficient to handle GeoSYM
I don't know what this is, but if SLD can handle it than yes.
Same as above.
SLD spec seems to say that a bit more work would be required to fully support it.
Yes
Not sure about GeoDEF - is it in the EPSG database? We support just about everything that has any sort of EPSG code, and include the full database by default.
(this and output formats can be quickly gleamed by looking at the capabilities document)
JPEG
Yes
GIF
Yes
SVG
Yes
PNG
Yes
Others
PDF, KML
RASTER
Raster support is still on a branch, but is pretty usable, and will be released relatively soon. The formats supported currently are:
     * GRIB edition 1
     * GeoTiff
     * WorldImages: PNG, JPG, TIFF, GIF with a world file attached
     * ArcGrid: ASCII files
     * GTOPO 30: DEM files
     * ImageMosaic: a mosaic of several images with world file or geotiff files. It is still quite experimental but it is showing good perfomances.
There is also work to integrate GDAL, which will mean support for:
http://gdal.maptools.org/formats_list.html
VECTOR
Shapefile
Yes.
VPF (VMAP, DNC)
Yes. (though not mature)
VRF (AML)
No?
S57 (AML, ENC)
No?
GML2/3
GML2
WFS
Yes.
SGBDR
No?
others formats
Unstable MapInfo support, and PostGIS, Oracle, MySQL, ArcSDE and DB2
3D
NetCDF
I think someone may be working on this
WCS
No immediate plans, but I've heard a few people mention it.
GRIB
Supported.
Performances
Very easy.
Plateform supported
Windows, Linux, Mac, ect. (it's java, so cross platform)
None that I know of, please let us know if you find any incompatibilities and we'll do our best to fix them.
Compliance with WFS
1.0, fully compliant with all levels (transactions and locking). In fact we are the reference implementation for WFS 1.0, and will be for 1.1 as well (work should be finished by december).
None.
Yes.
Yes.
Not yet, it's only in WFS 1.1
None, we fully support Filter encoding against any vector data format.
Would it be possible to get a copy of your final report?
best regards,
Chris
**Virginie Berre / Ingénieur étude et développement**
!DSPAM:1003,44d2083374821527717022!
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Just a little note on incompatibilities. In my testing I discovered that the WMS support built into ArcView v9.1 didn’t work completely. Specifically, the query function didn’t work.
Corey
the WMS support built into ArcView v9.1 didn't work completely.
Specifically, the query function didn't work.
Oh, that's because ArcView isn't spec compliant :slight_smile:
that said, the problem is well known and documented here:
http://jira.codehaus.org/browse/GEOS-533
The decision was to get geoserver be ArcView friendly and make the FORMAT
parameter in GetFeatureInfo not mandatory.
Last call for coments, if nobody is again I'll fix that both for 1.3.x and
trunk tomorrow/asap.
Gabriel.
Corey
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
Gabriel,
Yeah, I know ArcView isn’t spec compliant for querying. To be fair though, the spec is IMO rather braindead when it comes to the parameters that are required for a GetFeatureInfo request. It requires a bunch of parameters that are of no use or redundant to the query. :stuck_out_tongue:
BTW, ArcView also doesn’t send a LAYER parameter in addition to the FORMAT parameter. So resolving GEOS-553 alone won’t be enough to get it working.
Corey
Oh, that’s because ArcView isn’t spec compliant :slight_smile:
Last call for coments, if nobody is again I’ll fix that both for 1.3.x and
Gabriel.
Corey
