Hi
I exported the raster file to GeoTiff file with ArcMap. I do this with other raster and worked.
Running gdalinfo →
On linux:
Driver: GTiff/GeoTIFF
Size is 7356, 5164
Coordinate System is `’
Origin = (205917.522610576415900,7714821.430936027318239)
Pixel Size = (5.000000000000000,-5.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15 18:42:01EDT $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( 205917.523, 7714821.431)
Lower Left ( 205917.523, 7689001.431)
Upper Right ( 242697.523, 7714821.431)
Lower Right ( 242697.523, 7689001.431)
Center ( 224307.523, 7701911.431)
Band 1 Block=64x64 Type=Byte, ColorInterp=Gray
Overviews: 1839x1291, 920x646, 460x323, 230x162, 115x81, 58x41
On windows:
Files: c:\andre\dir_esc\diresc1.tif
c:\andre\dir_esc\diresc1.aux
c:\andre\dir_esc\diresc1.rrd
Size is 7356, 5164
Coordinate System is:
PROJCS[“SAD_1969_UTM_Zone_23S”,
GEOGCS[“GCS_South_American_1969”,
DATUM[“South_American_1969”,
SPHEROID[“GRS_1967_Truncated”,6378160.0,298.25]],
PRIMEM[“Greenwich”,0.0],
UNIT[“Degree”,0.0174532925199433]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“False_Easting”,500000.0],
PARAMETER[“False_Northing”,10000000.0],
PARAMETER[“Central_Meridian”,-45.0],
PARAMETER[“Scale_Factor”,0.9996],
PARAMETER[“Latitude_Of_Origin”,0.0],
UNIT[“Meter”,1.0]]
Origin = (205917.522610576420000,7714821.430936027300000)
Metadata:
AREA_OR_POINT=Area
EDT $
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Min=1.000 Max=128.000
Minimum=1.000, Maximum=128.000, Mean=31.274, StdDev=39.253
Metadata:
STATISTICS_MINIMUM=1
STATISTICS_MAXIMUM=128
STATISTICS_MEAN=31.273708613527
STATISTICS_MEDIAN=16
STATISTICS_MODE=64
STATISTICS_STDDEV=39.25334066027
LAYER_TYPE=athematic
STATISTICS_HISTOBINVALUES=2085627|1556380|2294766|1616891|2584024|1742487|25
98907|1675532|
Histogram
1
0
Value
0
0
2085627
1
1556380
2
2294766
4
1616891
8
2584024
16
1742487
32
2598907
64
1675532
128
I’m using version of GeoServer 1.6.2a.
I follow these steps to create a new coverage
1)Config->Data->CoverageStores->New
2) Selected the Tagged Image File Format with Geographic Information dataset option.
3) Entered in the Coverage Dataset ID field. Then hit New.
4) Entered the path of my Geotiff file and hit button
->Here the geoserver return me this exception
The following exception was thrown:
java.lang.UnsupportedOperationException: GeoTiffMetadata2CRSAdapter::createCoordinateSystem:Only Geographic & Projected Systems are supported.
I put on this link the Geotiff file
http://andresilva.890m.com/arquivos/dir_esc.zip
Regards
André
André Silva
