I am using GeoServer version 1.6.4. It is available on
www.wetlandsofindia.org/geoserver
When I submit a new feature type, I clicks on Apply button and then Click on
Save button. It shows me the following error..
The following exception was thrown:
org.vfny.geoserver.global.ConfigurationException: Cannot Write to file:
/home/innoway/public_html/geoserver/data/featureTypes/sacon_chennai
and it is not able to create the folder by feature name now so i couldnt
able to access the feature. I have my data stored in PostgreSQL database.
Have you ensured that there are no issues with permissions on the file system?
Also, would you be able to provide the full stack trace from the error log so we can narrow down exactly where access to the file is failing.
-Justin
The following exception was thrown: org.vfny.geoserver.global.ConfigurationException: Cannot Write to file:
I am looking forward for the solution.
Santosh
Justin Deoliveira
OpenGeo - http://opengeo.org
Catalina.out file is 30MB. This is located in Tomcat's logs folder. Do you
want this file? There is no issue with permissions on the file systems.
Previsouly it used to save the data properly. But it was asking restart of
the tomcat to reflect the changes made. Even when I restart the Tomcat, I
dont see my data is loaded. I have kept the default username and password
for GeoServer and I hope you will see the problem.
If could narrow it down for a bit that would be great to save me having to search through the entire file. Perhaps can you just pull out the bit that deals with the error and send that?
-Justin
santy wrote:
Dear Justin,
Please let me know which error log you want?
Thanks & Regards,
Santosh
Justin Deoliveira
I am attahcing catalina.out file with this email. I have zipped the file.
There are 2 file catalina.rar and catalina1.rar. Well catalina1.rar is
latest log file. Now my tomcat is crashing aftre clicking the save button. I
am looking forwrad for the solution.
I took a look at the log files. I see a lot of out of memory errors. You may consider giving tomcat / geoserver more memory on startup. You can find more info for this here:
As for the error on saving... my guess would be that the tomcat security setup is restricting writes to the file system. A user just had this issue recently, and described the solution in this thread:
Give that a shot. If you still have problems let us know.
-Justin
santy wrote:
Dear Justin,
