I followed geoserver imagepyramid plugin to write the plugin for reading our
proprietary pyramid data. The code was developed on Ubuntu platform using
Eclipse IDE and java 1.7. I built the jar file and dropped it onto the
WEB-INF/lib of Geoserver-2.5. When I restarted geoserver and clicked
"Add New Store", I saw my extension showed up under the "Raster Data
Sources" and was able to add the store and publish the layer. However, when
I copied the JAR file onto the WEB-INF/lib of the same geoserver version on
CentOS platform and restarted Geoserver, I got the following errors. I have
no ideas what was wrong. My code is pure Java and it only depends on
geotools.
Not sure why Spring could not find the
org.geoserver.data.util.CoverageStoreUtils class. I inspected the
gs-main-2.5.jar and the class is in there.
BeanCreationNotAllowedException: Error creating bean with name
'metaTileCache': Singleton bean creation not allowed while the singletons of
this factory are in destruction (Do not request a bean from a BeanFactory in
a destroy method implementation!)
2014-07-16 15:23:02,447 ERROR
[org.springframework.web.context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'restWrapper' defined in URL
[jar:file:/home/vriuser/geoserver-2.5/webapps/geoserver/WEB-INF/lib/gs-rest-2.5.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is
with name 'storeFileFinder' defined in URL
[jar:file:/home/vriuser/geoserver-2.5/webapps/geoserver/WEB-INF/lib/gs-restconfig-2.5.jar!/applicationContext.xml]:
Instantiation of bean failed; nested exception is
java.lang.NoClassDefFoundError: Could not initialize class
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
at
org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at
org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at
at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'storeFileFinder' defined in URL
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:288)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at
at
at
at
at
at
org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
at org.geoserver.rest.RESTDispatcher.addRoutes(RESTDispatcher.java:131)
at org.geoserver.rest.RESTDispatcher.createRoot(RESTDispatcher.java:231)
at
org.geoserver.rest.RESTDispatcher.initApplicationContext(RESTDispatcher.java:76)
at
org.springframework.context.support.ApplicationObjectSupport.initApplicationContext(ApplicationObjectSupport.java:119)
at
org.springframework.web.context.support.WebApplicationObjectSupport.initApplicationContext(WebApplicationObjectSupport.java:72)
at
org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:73)
at
org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:117)
at
org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:92)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
... 34 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class
at
org.geoserver.catalog.rest.StoreFileFinder.<clinit>(StoreFileFinder.java:24)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
at
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:121)
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:280)
... 54 more
Here is the pom.xml of my project:
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0
http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.vrinc</groupId>
<artifactId>ww-pyramid</artifactId>
<version>0.0.1-SNAPSHOT</version>
<packaging>jar</packaging>
<name>Vista pyramid datasource module</name>
<url>http://maven.apache.org</url>
<description>
Datasource created to read a pyramid of Worldwind cache data.
</description>
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<geotools.version>11.0</geotools.version>
<maven.compiler.target>1.7</maven.compiler.target>
<maven.compiler.source>1.7</maven.compiler.source>
</properties>
<dependencies>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>3.8.1</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.geotools</groupId>
<artifactId>gt-imagemosaic</artifactId>
<version>${geotools.version}</version>
</dependency>
</dependencies>
<repositories>
<repository>
<id>maven2-repository.dev.java.net</id>
<name>Java.net repository</name>
<url>http://download.java.net/maven/2</url>
</repository>
<repository>
<id>osgeo</id>
<name>Open Source Geospatial Foundation Repository</name>
<url>http://download.osgeo.org/webdav/geotools/</url>
</repository>
</repositories>
</project>
Let me know if you need more data. Many thanks in advance.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-extension-plugin-problem-when-deployed-on-different-platfrom-tp5151351.html
