Il giorno ven, 22/05/2015 alle 14.58 +0200, ELKHATTABI Imane ha scritto:
1- Actually , I didn't mess with the Postgre database connection .
Back when Geoserver was running , my data source had correct
connection details . And the layer were published with no issues.
Fine, but the log clearly contains an "authentication failed" exception
when a connection to PostgreSQL is attempted: may it be the case that
somebody (not necessarily you) has changed the password for the
"postgres" user, or the server configuration (e.g. blocking access from
certain IPs and/or to certain database/schema)? If you are sure that
none of this has happened, maybe the datastore.xml file holding
PostgreSQL's connection parameters got corrupted somehow...
2- I'm attaching to this mail the featuretype xml file regarding the
layer 'dim_bts_geo'.
Looks good to me.
3- Under Apache's webapps folder, there's Geoserver folder generated
from war that has all my data .Besides that , there's my web-mapping
app. This latter is related to geoserver , since it calls wms layer
from Geoserver to be displayed on a map.
OK.
4- Now, I tried this : I replaced the Geoserver folder that couldn't
start and generated another one by executing the war .Then I replaced
the 'data' repository by the previews one that had all my data .
When I run Apache, Geoserver starts, however when I see that all my
previews layers aren't active . When I try to republish them . I get
this error : Failed to load attribute list, internal error is: null
That's exactly the error I get if I shutdown Postgres and start
GeoServer afterwards: could you post the new logs?
Best regards,
Stefano Costa
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
