[Geoserver-users] Geoserver fails to display after SLD change
I was trying to style these stream lines using some SLD (both in the .zip at the link below) that I pieced together from Udig output when GeoServer 1.6.3 installed on Windows stopped displaying the data. The SLD validates using the validate functionality of Udig and geoserver doesn’t complain about anything.
But now I can’t get any WMS or anything from these data.
http://northredoubt.com/tmp/FFX_NHD.zip
It also seems to have broken the Demo functionality available from the Geoserver admin screens. They throw 500 errors when I try to open the demo page.
I’m pretty sure all I did was change the SLD on this layer!
How do I log these exception errors? This is all I can get from the console.
Thanks!
107422 [btpool0-6] ERROR org.mortbay.log - Nested in javax.servlet.ServletExcept
ion:
java.lang.NullPointerException
at org.vfny.geoserver.action.MapPreviewAction.computeGroupCoverageStatus
(MapPreviewAction.java:290)
at org.vfny.geoserver.action.MapPreviewAction.execute(MapPreviewAction.j
ava:261)
at org.apache.struts.action.RequestProcessor.processActionPerform(Reques
tProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.ja
va:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:119
6)
at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Servlet
Handler.java:1054)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCha
racterEncodingFilter.java:108)
Handler.java:1045)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
Handler.java:1045)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
Handler.java:1045)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(F
ilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Filt
erSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Fi
lterSecurityInterceptor.java:72)
ilterChainProxy.java:274)
Hi John,
I am not sure they are related. I just tried the data you posted and it works ok for me. From the exception it seems there are problems with base maps. Have you added any base maps or anything?
Zastrow, John wrote:
I was trying to style these stream lines using some SLD (both in the .zip at the link below) that I pieced together from Udig output when GeoServer 1.6.3 installed on Windows stopped displaying the data. The SLD validates using the validate functionality of Udig and geoserver doesn't complain about anything.
But now I can't get any WMS or anything from these data.
I'm pretty sure all I did was change the SLD on this layer!
Thanks!
ion:
ava:261)
va:236)
6)
Handler.java:1054)
Handler.java:1045)
Handler.java:1045)
Handler.java:1045)
!DSPAM:4007,48171020278292090977483!
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
