I setup geoserver to run as a daemon per the documentation. Below is a copy of my geoserver file located in init.d. I have ensure the permissions are set on the file. When I run service geoserver start here is the error i receive.
root@anonymised.com:/usr/share/geoserver/logs# service geoserver start
Failed to start geoserver.service: Unit geoserver.service failed to load: No such file or directory.
When I start it using the startup.sh I have no issues.
#! /bin/sh
BEGIN INIT INFO
Provides: geoserver
Required-Start: $local_fs $remote_fs
Required-Stop: $local_fs $remote_fs
Default-Start: 2 3 4 5
Default-Stop: S 0 1 6
Short-Description: GeoServer OGC server
END INIT INFO
Author: Lennart Jütte <lenn@anonymised.com>
Geoserver configuration - use /etc/default/geoserver to override these vars
user that shall run GeoServer
USER=geoserver
GEOSERVER_DATA_DIR=/usr/share/geoserver/data_dir
GEOSERVER_HOME=/usr/share/geoserver
PATH=/usr/sbin:/usr/bin:/sbin:/bin
DESC=“GeoServer daemon”
NAME=geoserver
JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk-amd64
JAVA_OPTS=“-Xms128m -Xmx512m”
DAEMON=“$JAVA_HOME/bin/java”
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
DAEMON_ARGS=“$JAVA_OPTS $DEBUG_OPTS -DGEOSERVER_DATA_DIR=$GEOSERVER_DATA_DIR -Djava.awt.headless=true -jar start.jar”
Load the VERBOSE setting and other rcS variables
[ -f /etc/default/rcS ] && . /etc/default/rcS
Define LSB log_* functions.
Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
. /lib/lsb/init-functions
do_start(){
Return
0 if daemon has been started
1 if daemon was already running
2 if daemon could not be started
start-stop-daemon --start --pidfile $PIDFILE --make-pidfile
–chuid $USER --chdir $GEOSERVER_HOME
-b --test --exec $DAEMON – $DAEMON_ARGS > /dev/null
|| return 1
-b --exec $DAEMON – $DAEMON_ARGS
|| return 2
do_stop(){
Return
0 if daemon has been stopped
1 if daemon was already stopped
2 if daemon could not be stopped
other if a failure occurred
start-stop-daemon --stop --pidfile $PIDFILE
–user $USER
–retry=TERM/30/KILL/5
RETVAL=“$?”
[ “$RETVAL” = 2 ] && return 2
Many daemons don’t delete their pidfiles when they exit.
rm -f $PIDFILE
return “$RETVAL”
case “$1” in
start)
[ “$VERBOSE” != no ] && log_daemon_msg “Starting $DESC” “$NAME”
do_start
case “$?” in
0|1) [ “$VERBOSE” != no ] && log_end_msg 0 ;;
2) [ “$VERBOSE” != no ] && log_end_msg 1 ;;
esac
stop)
[ “$VERBOSE” != no ] && log_daemon_msg “Stopping $DESC” “$NAME”
do_stop
case “$?” in
esac
restart|force-reload)
log_daemon_msg “Restarting $DESC” “$NAME”
do_stop
case “$?” in
0|1)
do_start
case “$?” in
0) log_end_msg 0 ;;
- log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
Failed to stop
log_end_msg 1
esac
#echo “Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}” >&2
echo “Usage: $SCRIPTNAME {start|stop|restart|force-reload}” >&2
exit 3
esac
