Hello all,
I have installed on centos 5.9 tomcat5 ja deployed on it geoserver 2.2.4.
First start was not successful, because of "out-of-memory".
I did some google-search and add on environment for java
JAVA_OPTS="-Xms128m -Xmx512m -XX:MaxPermSize=256m"
After that when trying to start geoserver, I get error and logs shows as following:
2013-02-18 10:04:49,720 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [orggeotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
2013-02-18 10:04:50,070 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /usr/share/tomcat5/webapps/geoserver/data
2013-02-18 10:04:50,219 INFO [org.geoserver] - Loaded style 'tiger_roads'
2013-02-18 10:04:50,233 INFO [org.geoserver] - Loaded style 'point'
2013-02-18 10:04:50,234 INFO [org.geoserver] - Loaded style 'restricted'
2013-02-18 10:04:50,249 INFO [org.geoserver] - Loaded style 'capitals'
2013-02-18 10:04:50,255 INFO [org.geoserver] - Loaded style 'pophatch'
2013-02-18 10:04:50,263 INFO [org.geoserver] - Loaded style 'cite_lakes'
2013-02-18 10:04:50,268 INFO [org.geoserver] - Loaded style 'polygon'
2013-02-18 10:04:50,269 INFO [org.geoserver] - Loaded style 'rain'
2013-02-18 10:04:50,270 INFO [org.geoserver] - Loaded style 'poi'
2013-02-18 10:04:50,276 INFO [org.geoserver] - Loaded style 'grass'
2013-02-18 10:04:50,277 INFO [org.geoserver] - Loaded style 'raster'
2013-02-18 10:04:50,288 INFO [org.geoserver] - Loaded style 'dem'
2013-02-18 10:04:50,289 INFO [org.geoserver] - Loaded style 'poly_landmarks'
2013-02-18 10:04:50,290 INFO [org.geoserver] - Loaded style 'population'
2013-02-18 10:04:50,301 INFO [org.geoserver] - Loaded style 'line'
2013-02-18 10:04:50,312 INFO [org.geoserver] - Loaded style 'simple_streams'
2013-02-18 10:04:50,316 INFO [org.geoserver] - Loaded style 'green'
2013-02-18 10:04:50,320 INFO [org.geoserver] - Loaded style 'simple_roads'
2013-02-18 10:04:50,339 INFO [org.geoserver] - Loaded style 'burg'
2013-02-18 10:04:50,344 INFO [org.geoserver] - Loaded style 'giant_polygon'
2013-02-18 10:04:50,355 INFO [org.geoserver] - Loaded default workspace it.geosolutions
2013-02-18 10:04:50,377 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
2013-02-18 10:04:50,396 INFO [org.geoserver] - Loaded workspace 'tiger'
2013-02-18 10:04:50,426 INFO [org.geoserver] - Loaded workspace 'sf'
2013-02-18 10:04:50,442 INFO [org.geoserver] - Loaded workspace 'cite'
2013-02-18 10:04:50,445 INFO [org.geoserver] - Loaded workspace 'topp'
2013-02-18 10:04:50,466 INFO [org.geoserver] - Loaded workspace 'nurc'
2013-02-18 10:04:50,483 INFO [org.geoserver] - Loaded workspace 'sde'
2013-02-18 10:04:51,929 INFO [org.geoserver] - Loaded store 'nyc', enabled
2013-02-18 10:04:51,935 INFO [org.geoserver] - Loaded data store 'nyc'
2013-02-18 10:04:53,853 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2013-02-18 10:04:54,278 INFO [org.geoserver] - Loaded feature type 'giant_polygon', enabled
2013-02-18 10:04:54,287 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-02-18 10:04:54,307 INFO [org.geoserver] - Loaded layer 'giant_polygon'
2013-02-18 10:04:54,319 INFO [org.geoserver] - Loaded feature type 'poi', enabled
2013-02-18 10:04:54,320 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-02-18 10:04:54,322 INFO [org.geoserver] - Loaded layer 'poi'
2013-02-18 10:04:54,329 INFO [org.geoserver] - Loaded feature type 'tiger_roads', enabled
2013-02-18 10:04:54,329 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-02-18 10:04:54,340 INFO [org.geoserver] - Loaded layer 'tiger_roads'
2013-02-18 10:04:54,346 INFO [org.geoserver] - Loaded feature type 'poly_landmarks', enabled
2013-02-18 10:04:54,347 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-02-18 10:04:54,350 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
2013-02-18 10:04:54,370 INFO [org.geoserver] - Loaded store 'sf', enabled
2013-02-18 10:04:54,371 INFO [org.geoserver] - Loaded data store 'sf'
2013-02-18 10:04:54,925 INFO [org.geoserver] - Loaded feature type 'restricted', enabled
2013-02-18 10:04:54,925 INFO [org.geoserver] - Loaded feature type 'sf'
2013-02-18 10:04:54,941 INFO [org.geoserver] - Loaded layer 'restricted'
2013-02-18 10:04:54,953 INFO [org.geoserver] - Loaded feature type 'roads', enabled
2013-02-18 10:04:54,953 INFO [org.geoserver] - Loaded feature type 'sf'
2013-02-18 10:04:54,955 INFO [org.geoserver] - Loaded layer 'roads'
2013-02-18 10:04:54,973 INFO [org.geoserver] - Loaded feature type 'bugsites', enabled
2013-02-18 10:04:54,974 INFO [org.geoserver] - Loaded feature type 'sf'
2013-02-18 10:04:54,975 INFO [org.geoserver] - Loaded layer 'bugsites'
2013-02-18 10:04:54,984 INFO [org.geoserver] - Loaded feature type 'archsites', enabled
2013-02-18 10:04:54,985 INFO [org.geoserver] - Loaded feature type 'sf'
2013-02-18 10:04:54,987 INFO [org.geoserver] - Loaded layer 'archsites'
2013-02-18 10:04:54,995 INFO [org.geoserver] - Loaded feature type 'streams', enabled
2013-02-18 10:04:54,996 INFO [org.geoserver] - Loaded feature type 'sf'
2013-02-18 10:04:54,998 INFO [org.geoserver] - Loaded layer 'streams'
2013-02-18 10:04:55,013 INFO [org.geoserver] - Loaded store 'sfdem', enabled
2013-02-18 10:04:55,021 INFO [org.geoserver] - Loaded coverage store 'sfdem'
2013-02-18 10:04:55,072 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
2013-02-18 10:04:55,081 INFO [org.geoserver] - Loaded coverage 'sfdem'
2013-02-18 10:04:56,397 INFO [org.geoserver] - Loaded layer 'sfdem'
2013-02-18 10:04:56,418 INFO [org.geoserver] - Loaded store 'states_shapefile', enabled
2013-02-18 10:04:56,418 INFO [org.geoserver] - Loaded data store 'states_shapefile'
2013-02-18 10:04:56,434 INFO [org.geoserver] - Loaded feature type 'states', enabled
2013-02-18 10:04:56,434 INFO [org.geoserver] - Loaded feature type 'states_shapefile'
2013-02-18 10:04:56,444 INFO [org.geoserver] - Loaded layer 'states'
2013-02-18 10:04:56,469 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
2013-02-18 10:04:56,471 INFO [org.geoserver] - Loaded data store 'taz_shapes'
2013-02-18 10:04:56,491 INFO [org.geoserver] - Loaded feature type 'tasmania_cities', enabled
2013-02-18 10:04:56,491 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-02-18 10:04:56,492 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
2013-02-18 10:04:56,495 INFO [org.geoserver] - Loaded feature type 'tasmania_state_boundaries', enabled
2013-02-18 10:04:56,495 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-02-18 10:04:56,496 INFO [org.geoserver] - Loaded layer 'tasmania_state_boundaries'
2013-02-18 10:04:56,499 INFO [org.geoserver] - Loaded feature type 'tasmania_water_bodies', enabled
2013-02-18 10:04:56,500 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-02-18 10:04:56,503 INFO [org.geoserver] - Loaded layer 'tasmania_water_bodies'
2013-02-18 10:04:56,505 INFO [org.geoserver] - Loaded feature type 'tasmania_roads', enabled
2013-02-18 10:04:56,506 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-02-18 10:04:56,507 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
2013-02-18 10:04:56,525 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
2013-02-18 10:04:56,525 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
2013-02-18 10:04:56,535 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
2013-02-18 10:04:56,536 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
2013-02-18 10:04:56,667 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
2013-02-18 10:04:56,681 INFO [org.geoserver] - Loaded store 'worldImageSample', enabled
2013-02-18 10:04:56,682 INFO [org.geoserver] - Loaded coverage store 'worldImageSample'
2013-02-18 10:04:56,686 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
2013-02-18 10:04:56,687 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
2013-02-18 10:04:56,889 INFO [org.geoserver] - Loaded layer 'Img_Sample'
2013-02-18 10:04:56,908 INFO [org.geoserver] - Loaded store 'img_sample2', disabled
2013-02-18 10:04:56,908 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
2013-02-18 10:04:56,979 INFO [org.geoserver] - Loaded coverage 'Pk50095', disabled
2013-02-18 10:04:56,979 INFO [org.geoserver] - Loaded coverage 'img_sample2'
2013-02-18 10:04:56,980 INFO [org.geoserver] - Loaded layer 'Pk50095'
2013-02-18 10:04:56,987 INFO [org.geoserver] - Loaded store 'mosaic', enabled
2013-02-18 10:04:56,987 INFO [org.geoserver] - Loaded coverage store 'mosaic'
2013-02-18 10:04:57,003 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
2013-02-18 10:04:57,004 INFO [org.geoserver] - Loaded coverage 'mosaic'
2013-02-18 10:04:57,095 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: mosaic
2013-02-18 10:04:57,496 WARN [imagemosaic.Utils] - Unable to find sample image for path /usr/share/tomcat5/webapps/geoserver/data/coverages/mosaic_sample/sample_image
2013-02-18 10:04:57,496 WARN [gce.imagemosaic] - Unable to find sample image for path file:/usr/share/tomcat5/webapps/geoserver/data/coverages/mosaic_sample/mosaic.shp
2013-02-18 10:04:57,496 INFO [org.geoserver] - Loaded layer 'mosaic'
2013-02-18 10:04:57,512 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
2013-02-18 10:04:57,524 INFO [org.geoserver] - Loaded layer group 'tasmania'
2013-02-18 10:04:57,525 INFO [org.geoserver] - Loaded layer group 'spearfish'
2013-02-18 10:04:57,588 INFO [storage.DefaultStorageFinder] - ***************************************************************************************
2013-02-18 10:04:57,588 INFO [storage.DefaultStorageFinder] - *** Reverting to java.io.tmpdir null for storage. Please set GEOWEBCACHE_CACHE_DIR. ***
2013-02-18 10:04:57,588 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in '/usr/share/tomcat5/temp/geowebcache'
2013-02-18 10:04:58,781 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2013-02-18 10:04:58,873 INFO [org.geoserver] - Loaded service 'wcs', enabled
2013-02-18 10:04:58,899 INFO [org.geoserver] - Loaded service 'wfs', enabled
2013-02-18 10:04:58,921 INFO [org.geoserver] - Loaded service 'wms', enabled
2013-02-18 10:04:58,938 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2013-02-18 10:04:58,970 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
2013-02-18 10:04:58,970 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /usr/share/tomcat5/webapps/geoserver/data/gwc-layers
2013-02-18 10:04:58,981 INFO [gwc.layer] - Loading tile layers from /usr/share/tomcat5/webapps/geoserver/data/gwc-layers
2013-02-18 10:04:59,209 INFO [gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
2013-02-18 10:04:59,218 INFO [config.XMLConfiguration] - Found configuration file in /usr/share/tomcat5/temp/geowebcache
2013-02-18 10:04:59,269 INFO [config.XMLConfiguration] - Configuration file validated fine.
2013-02-18 10:04:59,276 INFO [config.XMLConfiguration] - Initializing GridSets from /usr/share/tomcat5/temp/geowebcache
2013-02-18 10:04:59,276 INFO [config.XMLConfiguration] - Initializing layers from /usr/share/tomcat5/temp/geowebcache
2013-02-18 10:04:59,276 INFO [layer.TileLayerDispatcher] - Configuration /usr/share/tomcat5/temp/geowebcache contained no layers.
2013-02-18 10:04:59,444 INFO [storage.EntityStoreBuilder] - Neither disk quota page store' cache memory percent nor cache size was provided. Defaulting to 25% Heap Size
2013-02-18 10:05:01,977 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota page store configured at /usr/share/tomcat5/temp/geowebcache/diskquota_page_store
2013-02-18 10:05:01,978 INFO [storage.BDBQuotaStore] - Quota Store initialized. Global quota: 0.0 B
2013-02-18 10:05:01,986 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /usr/share/tomcat5/temp/geowebcache/geowebcache-diskquota.xml
2013-02-18 10:05:01,990 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2013-02-18 10:05:01,993 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2013-02-18 10:05:01,993 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to global quota 500.0 MB
2013-02-18 10:05:02,008 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2013-02-18 10:05:02,247 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler 'dispatcher'
2013-02-18 10:05:02,318 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2013-02-18 10:05:02,341 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job...
2013-02-18 10:05:02,417 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 13 paths
2013-02-18 10:05:02,449 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2013-02-18 10:05:02,449 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2013-02-18 10:05:02,487 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
2013-02-18 10:05:02,487 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
2013-02-18 10:05:02,497 INFO [org.geoserver] - GeoServer configuration lock is enabled
2013-02-18 10:05:02,574 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2013-02-18 10:05:02,748 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
2013-02-18 10:05:02,748 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
2013-02-18 10:05:04,102 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler 'dispatcher'
2013-02-18 10:05:04,102 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler 'wfsTestServlet'
2013-02-18 10:05:04,102 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler 'dispatcher'
2013-02-18 10:05:08,485 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler 'dispatcher'
2013-02-18 10:05:08,485 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler 'dispatcher'
2013-02-18 10:05:08,636 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler 'dispatcher'
2013-02-18 10:05:08,636 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler 'dispatcher'
2013-02-18 10:05:08,638 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler 'dispatcher'
2013-02-18 10:05:08,638 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler 'dispatcher'
2013-02-18 10:05:08,731 WARN [geoserver.security] - /var/lib/tomcat5/webapps/geoserver/data/security/masterpw.info is a security risk. Please read this file and remove it afterward
2013-02-18 10:05:08,738 ERROR [[localhost].[/geoserver]] - Exception sending context initialized event to listener instance of class org.geoserver.platform.GeoServerContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error occured reading security configuration; nested exception is java.io.FileNotFoundException: /usr/share/tomcat5/webapps/geoserver/data/security/config.xml (No such file or directory)
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:329)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:324)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:21)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3764)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4212)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:760)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:740)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:880)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:732)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1193)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfigjava:319)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:120)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start(StandardService.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
Caused by: java.io.FileNotFoundException: /usr/share/tomcat5/webapps/geoserver/data/security/config.xml (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:137)
at org.geoserver.security.GeoServerSecurityManager.loadConfigFile(GeoServerSecurityManager.java:2237)
at org.geoserver.security.GeoServerSecurityManager.loadConfigFile(GeoServerSecurityManager.java:2251)
at org.geoserver.security.GeoServerSecurityManager.loadSecurityConfig(GeoServerSecurityManager.java:2221)
at org.geoserver.security.GeoServerSecurityManager.init(GeoServerSecurityManager.java:403)
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:322)
... 27 more
2013-02-18 10:05:08,741 INFO [georss.GeoRSSPoller] - destroy() invoked
2013-02-18 10:05:08,742 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2013-02-18 10:05:08,746 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down...
2013-02-18 10:05:08,746 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor...
2013-02-18 10:05:08,746 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor...
2013-02-18 10:05:08,746 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2013-02-18 10:05:08,746 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor...
2013-02-18 10:05:08,747 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2013-02-18 10:05:08,747 INFO [storage.BDBQuotaStore] - Requesting to close quota store...
2013-02-18 10:05:08,752 INFO [storage.BDBQuotaStore] - Quota store closed.
2013-02-18 10:05:08,752 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks...
2013-02-18 10:05:08,752 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2013-02-18 10:05:08,753 INFO [storage.StorageBroker] - Destroying StorageBroker
2013-02-18 10:05:10,043 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'GWCLifeCycleHandler': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
I haven't found anything for this.
Can somebody help me?
-pk
Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
